Sounds like a big upgrade, shame LB are so expensive now.Mr Purple wrote: ↑Thu Jul 06, 2023 5:38 pmAnd it is done! Thanks @biker jk.
Ordered the Farsports 30mm depth, 25mm internal diameter hookless gravel wheels with DT350 hubs in matte black.
An old Hambini review also yielded a discount code of 'HAMBINI50' which was another $74 odd off. So $1170 delivered. Pretty hard to argue with 1370g for that.
Managed to work out the weight of my Bontragers on my ALR5 today - apparently it's over 2.1kg with the rim strips. They're also only 21mm internal diameter and the hubs aren't serviceable so definitely the entry level choice by Trek there.
Should make a bit of a difference. Also fitted the Hope carbon seatpost off my Bowman and a Selle Italia SL-R Kit carbonio today. Wasn't really looking for weight savings (more comfort) but it still dropped the seat/post combo from 520g to 260g. So the bike should be about 1.1kg lighter when the wheels arrive. Nice.
Gravel wheels
Re: Gravel wheels
Postby blizzard » Thu Jul 06, 2023 9:19 pm
Re: Gravel wheels
Postby Mr Purple » Fri Jul 07, 2023 6:46 am
That’s crazy for Chinese wheels. I’d spend a little extra and get Zipp 303s for that price.
Re: Gravel wheels
Postby warthog1 » Fri Jul 07, 2023 11:51 am
Those far sports are a great price.
- mogwaiboi
Re: Gravel wheels
Postby mogwaiboi » Mon Jul 31, 2023 11:27 am
Re: Gravel wheels
Postby Mr Purple » Mon Jul 31, 2023 2:43 pm
Thanks for the feedback. They're certainly not quick with the postage - posted 21 calendar days after ordering, but the tracking seems to be working, will post some pictures when they arrive.
Only problem is now I'm looking at their 'Kaze' with DT240 hubs for road bike. Will get my disc braked road bike under 7kg for not very much, which is tempting!
- biker jk
Re: Gravel wheels
Postby biker jk » Mon Jul 31, 2023 4:34 pm
Mine were delivered two weeks after ordering. They were in stock and didn't need to be built.Mr Purple wrote: ↑Mon Jul 31, 2023 2:43 pmThanks for the feedback. They're certainly not quick with the postage - posted 21 calendar days after ordering, but the tracking seems to be working, will post some pictures when they arrive.
- mogwaiboi
Re: Gravel wheels
Postby mogwaiboi » Tue Aug 01, 2023 11:20 am
I'd be looking at the gravel wheels for road as well, more choice of wider widths. I've got the Kaze 28mm external and the gravel 32mm external, gravel set is lighter. I use the Kaze for light gravel and the gravel wheels for all roadMr Purple wrote: ↑Mon Jul 31, 2023 2:43 pmThanks for the feedback. They're certainly not quick with the postage - posted 21 calendar days after ordering, but the tracking seems to be working, will post some pictures when they arrive.
From memory the Kaze series are a bit more robust so weigh a little bit more. I used the Kaze for rough gravel initially before I got my Grizl and they were bulletproof.
Re: Gravel wheels
Postby Mr Purple » Tue Aug 01, 2023 11:58 am
I thought Kaze were the light ones at 1270g in 35mm, but no the 'Hyper' come in at 1230g for around the same price. Crazy!
My road frameset is a crazy light (790g) 2017 Focus Izalco Max Disc, so one of the disadvantages is limited tyre clearance. They may apparently take 28mm but everything says 'but this depends' so I think I'll stick with 26mm wide rims and 26mm tyres.
With a couple of other small changes this should get it close to 6.8kg and not get me in trouble for buying a new bike. I can see 28mm and Di2 at some stage in my future though - it'll have to wait for another frame.
Re: Gravel wheels
Postby Mr Purple » Fri Aug 04, 2023 3:20 pm
Nothing too fancy - the newer DT350 hubs, 30mm depth, 25mm internal diameter hookless.
They look brilliant.
723g rear.
620g front.
So 1344g of a quoted weight of 1370g. I won't be sending them back because they're too light! For a wide, 'not particularly exotically specced' wheelset that's seriously impressive.
Very impressed by the wheels. Service is definitely a lot more 'no frills' than Light Bicycle, but if you know what you're ordering and don't need your hand held through the process you'll save $400-600.
Only problem is now my gravel wheelset is about 300g lighter than my road. Time to start saving a bit more!
- Retrobyte
Re: Gravel wheels
Postby Retrobyte » Fri Aug 04, 2023 3:48 pm
I was very happy with my Farsports ordering experience as well, and the wheels (road, not gravel) have been faultless and troublefree for close to 3 years now. Still nicely trued despite my 95 kilos of abuse.
- MichaelB
Re: Gravel wheels
Postby MichaelB » Fri Aug 04, 2023 7:16 pm
Re: Gravel wheels
Postby Mr Purple » Wed Aug 09, 2023 1:23 pm
Sorry for the dodgy photo. Weight savings of 330g for the front only, will do the rear next week.
Of course now the brake offset is slightly different so I'll probably drop it off for a full service and adjustment before riding it, but can see this being a lot faster immediately!
Re: Gravel wheels
Postby Mr Purple » Sun Sep 10, 2023 1:34 pm
Pathfinder Pro S-Works 42mm. Bike weight is now down to 9.3kg with cages. Not as light as I expected given factory is 9.75kg but I probably should have weighed it before I started modifying. In my defence I started modifying before I even picked it up.
Brief spin on the road to bed in the sealant confirms it feels a lot lighter than it did before. Probably a combination of the 500g or so saved, the decent 350 hubs and a bit less rolling resistance from the Pathfinders.
Will feed it a few more KOMs next weekend.
Re: Gravel wheels
Postby Mr Purple » Sun Sep 10, 2023 4:32 pm
Re: Gravel wheels
Postby warthog1 » Sun Sep 10, 2023 8:26 pm
The wheels look good, good buy.
Re: Gravel wheels
Postby Mr Purple » Sun Sep 17, 2023 5:29 pm
Change of plans so only managed a short gravel ride today. The combo of the new wheels and pathfinders is notably faster.
Took two KOMs, one a downhill tarmac segment (!). The other was a 6.9% climb through a park complete with grass and tree roots. Was previously a second off the 1:22 record after a few attempts. 1:12.
You just don’t notice the tyres are there either on gravel or tarmac. That’s all I ask of gravel tyres. That and the air staying inside, which will take a bit longer to judge.
Re: Gravel wheels
Postby warthog1 » Sun Sep 17, 2023 7:26 pm
Thanks, if they stay reliable they sound good.Mr Purple wrote: ↑Sun Sep 17, 2023 5:29 pmChange of plans so only managed a short gravel ride today. The combo of the new wheels and pathfinders is notably faster.
Re: Gravel wheels
Postby Mr Purple » Sun Oct 08, 2023 1:16 pm
https://lightweight.info/en/wheels/pfadfinder-evo
Yes, they look ok, with a few slight issues:
1. Maximum 40mm tyres. On a gravel wheel. What?
2. They weigh 1427g. 'Lightweight'.
3. They're $6999 a set, or $7799 if you want the 'Schwarz' Edition. I.e. the same thing in black.
Um. Are people stupid? Considering my Farsports were $1200 odd, 1351g and will take up to 50mm tyres without a problem I have no idea who is buying these things. I suspect, in Australia at least, 'no-one'.
- MichaelB
Re: Gravel wheels
Postby MichaelB » Mon Oct 09, 2023 2:09 pm
And as an example at the opposite end of the spectrum, just snaffled a lightly used set of G1800's (the ones I tried to buy earlier but mistakenly bought the 27.5" version ... ) for $325 shipped to the door, so that'd leave me with an extra $7,474 to spend on a two week riding holiday to Italy or Andorra .....Mr Purple wrote: ↑Sun Oct 08, 2023 1:16 pmIn the 'things I would recommend not buying' column there was a feature on the Lightwehgt Pfadfinder EVO gravel wheelset in the latest Australia/NZ Cyclist magazine.
Backstory is that I managed to get a replacement rim for the rear one I killed, but will use that wheelset as the roadie/commute for the ICAN, and use the G1800's as the Gravel wheelset.
Re: Gravel wheels
Postby Scott No Mates » Wed Jan 03, 2024 8:09 pm
Pretty sure that I can't go any wider than 28mm.
PS. I note that @Propagate passed away mid-race in March 2022
memberlist.php?mode=viewprofile&u=36284
Re: Gravel wheels
Postby owly » Thu Jan 04, 2024 10:19 am
Scott No Mates wrote: ↑Wed Jan 03, 2024 8:09 pmIs it necessary or recommended to swap out my Conti GP 5000 or the Gatorskins for some 25-28mm gravel tyres if taking my roadies on some rail trails?
I would, for some better grip.
IRC Marbella comes in a 28mm and is supposed to measure closer to a 27mm or less when mounted.
Return to “Cyclocross and Gravel Grinding”
