Favero assioma duo shi
MichaelB
Re: Favero assioma duo shi
Postby MichaelB » Fri Apr 21, 2023 4:31 pm
Mr Purple wrote:
Fri Apr 21, 2023 11:40 am
Who'd you order from? That seems like a decent deal, though I sort of promised myself I wouldn't be measuring power on my gravel bike I do miss it!
Looks like Favero only say to use the PD-M540 or 550 for the conversion. Pretty sure that's not correct, but wasn't sure if you knew.
Bought from here
https://www.ebay.com.au/itm/27508907557 ... media=COPY
When I did it, there was a $60 voucher as well.
Still $40 cheaper than Pushys and quicker delivery.
The trainer Road thread linked earlier and also a post from me lists many different off-road options that fit easy
MichaelB
Postby MichaelB » Fri Apr 21, 2023 4:42 pm
These are the pedals that have been shown to work in the Trainer Road thread (and more being successfully tried as well)
xPedo
M-Force 4 - These don’t appear to be available
M-Force 8 - Available but expensive and there seems to be a lot of poor user reviews.
CXR - Needs locktite and can’t be torqued up without binding so not ideal if swapping back and forth between SPD and Road pedal bodies
TVRS Duo
Bontrager Comp - I think these are a straight and easy swap
Wellgo M19 - I think these are a straight and easy swap
ISSI Flash/Flip/Trail 3 - straight easy swap but must be v III
Shimano
PD M8000
PD A600
PD M520
PD EH500
MichaelB
Postby MichaelB » Sun May 14, 2023 7:00 pm
Well, after receiving the pedals the other day, and finally getting around to it, it took the grad total of 3 min to complete the swap.
I have to pull them apart to fit the o-rings per this image from the Trainer Road thread. Not my pedals below, but the pic is the same (apart from the aforementioned o-rings.
But apart from finishing initial charge and sorting out a clunk in the BB, they are ready to go !!!
foo on patrol
Postby foo on patrol » Mon May 15, 2023 4:09 pm
8)
Foo
Goal 6000km
MichaelB
Postby MichaelB » Wed May 17, 2023 1:18 pm
A quick session in the shed last night had the pedals fitted, calibrated and tested.
All schmick and ready for test ride Thur morning !!
MichaelB
Postby MichaelB » Fri Nov 17, 2023 8:32 am
After all the really workable hacks to get gravel pedal PM's using the Assioma Duo Shimano spindles, lo and behold, they've released their own
https://cycling.favero.com/it/shop/assi ... 2-preserie
Key MAJOR improvement is the pods have gone !
In the drop down menu on the right, you can select english. Shimano SPD cleat compatible
Bargain !!!
warthog1
Postby warthog1 » Fri Nov 17, 2023 9:31 am
They look great :)
ningnangnong
Postby ningnangnong » Fri Nov 17, 2023 10:36 am
Definitely interested, unfortunately looks like only available in Italy at the moment.
"Pre-series units available only in Italy in limited quantities."
