Varia RCT715 Radar/Camera
Re: Varia RCT715 Radar/Camera
Postby jasonc » Wed May 24, 2023 9:41 am
grt046 wrote:
Tue May 23, 2023 10:59 pm
Just seen on a mates new Synapse a Cannondale SmartsSense intergrated system incorporating Garmin Varia paired with Lezanne lighting (front and rear) together with powered Garmin GPS mount suitable for some Garmin Edge computers, 530 and above all supplied from a common battery which is detachable for charging.
Long Term Review by DC Rainmaker https://www.dcrainmaker.com/2023/02/can ... 1-rle.html
yeah great. so if you have more than one bike you need to have lights for each
and the radar is the non-camera version
grt046
Postby grt046 » Wed May 24, 2023 10:42 am
Yes agreed. Wouldn't suit me either as I swap all between two bikes.
Giant Defy Advanced 1 (2014) Orbea Gain M20 (2021)
Comedian
Postby Comedian » Sun Jun 11, 2023 1:30 pm
So I've found one issue with the Garmn rct715. It's impossible to buy replacement rubber straps for them. When you buy one you get two rubber straps in the kit, but they are not available from garmin full stop. Just not sold separately.
Eventually the straps stretch and start to loose their elasticity. Not sure what the answer is. Perhaps buying a new mount.. or zip tying the mount on.
Postby jasonc » Sun Jun 11, 2023 3:10 pm
But then servicing the bike in a work stand becomes difficult
Comedian
Postby Comedian » Sun Jun 11, 2023 3:25 pm
Good point. My workstand is a through axle one (remember those?) but that could be an issue for some.
Comedian
Postby Comedian » Mon Jul 10, 2023 11:31 am
Heads up to anyone on the fence on this. Pushy's currently has the 715 on special. Might be worth checking out if you are interested. Retail 649 but currently 569. Still not cheap I know.
Personally I don't mind paying for stuff that works, and keeps working. Unfortunately that hasn't been universal in this space of camera tail lights. As long as I get a couple of years out of it I'm in front.
caneye
Postby caneye » Wed Jul 12, 2023 11:32 am
have you found a substitute/replacement strap for the RCT715?
i'm thinking an alternative is possibly a big rubber o-ring (will need 2x) like those that come on some bike lights.
Comedian
Postby Comedian » Wed Jul 12, 2023 1:20 pm
I have not found anything - but you can cable tie them on. Potentially there would be o-rings that would do the trick but might need a bit of experimentation.
Comedian
Postby Comedian » Tue Aug 01, 2023 1:49 pm
So another interesting thing with the varia. The main button.. the documentation is really poor. If you press it .. it turns the camera off but the light might be on.
I went to look at footage of the motorbike last night and it hasn't been recording for a month. In the app it said record was off so I turned it back on and I think it's recording again.
lesson is if it doesn't put rec on the screen you need to look into it. My garmin also has a Varia page which magically appears and you can control the setup in there. You want video recording set to "on radar activity"
Comedian
Postby Comedian » Sat Oct 14, 2023 6:53 am
You can use a varia radar camera to record the speed of motorists in your favourite rat run! Trick is you need AUTOPAUSE = OFF on your headunit.
[shareyoutube]https://youtu.be/Z_-9atOvLZM[/shareyoutube]
Postby jasonc » Sat Oct 14, 2023 10:22 am
something has changed when sharing youtube videos. i have to strip out the code from the "embedded link"
there you go comedian
Retrobyte
Postby Retrobyte » Sat Oct 14, 2023 11:36 am
or if you go to the video on YouTube and click "share" and copy that link, it will work with the shareyoutube tags
Mr Purple
Postby Mr Purple » Mon Feb 26, 2024 10:48 am
So finally pressed the button on buying one of these things today - happily they're on a semi decent discount ($549) at Garmin themselves:
https://www.garmin.com/en-AU/p/721258
Will be interesting to see how it plays out. Currently using a Wahoo Bolt V2 so some of the functionality will be limited. Is the passing traffic speed still visible on the filmed video?
Postby jasonc » Mon Feb 26, 2024 11:21 am
i think that's done by the unit. so should still work
Mr Purple
Postby Mr Purple » Tue Feb 27, 2024 11:05 am
Thanks, looks to be the case. The display for the radar on the Wahoo actually looks pretty decent as well.
I'll see how it goes with the Wahoo for the moment. Unfortunately Wahoo seem to be doing that thing where every software update makes the Bolt a little bit worse. It's gone from something that 'just works' to something that now doesn't record elevation for the first few kilometres of the ride, doesn't seem to sync Strava live segments or pre-planned routes very well, and doesn't even automatically upload the ride when finished at all anymore - all needs to be done manually.
They really need to fire their software update team.
Postby jasonc » Tue Feb 27, 2024 11:13 am
My garmin spends the first 30 seconds to 1 minute doing an elevation correction. annoying in the afternoon as I head straight up a hill
warthog1
Postby warthog1 » Tue Feb 27, 2024 12:13 pm
Is that a 1040?
My 1030+ sometimes takes a while to find the vector3 pedals (after I have turned cranks by hand). I then calibrate them and away I go.
I am unaware of any "elevation correction" but I am an IT or electronics numpty.
Mr Purple
Postby Mr Purple » Tue Feb 27, 2024 12:35 pm
The vector crank issue is also a Wahoo problem. The other issue with the most recent update is that they changed the starting screen so you can't actually see what accessories have successfully registered via bluetooth - you don't find out you're missing your pedals or HRM until a few kilometres in the ride and then have to stop and reboot everything to find them.
Just find it really annoying. Software updates are supposed to make things better, not worse.
warthog1
Postby warthog1 » Tue Feb 27, 2024 12:42 pm
I just use stava elevation at the end of rides anyway. I don't see any head unit that uses barometric pressure being in any way accurate.
Mind you the strava data may just be a compilation of multiple device readings. Being multiple devices it should be slightly more accurate.
Postby jasonc » Tue Feb 27, 2024 1:23 pm
when i was paying for veloviewer i did a comparison of elevation for commute depending on the garmin device i was using. was interesting
warthog1
Postby warthog1 » Tue Feb 27, 2024 1:30 pm
My old 800 was very stingy in the amount of elevation it deigned to allocate a ride. :lol:
The 1030+ is more generous but almost always less than Strava gives.
Mr Purple
Postby Mr Purple » Fri Mar 01, 2024 7:01 pm
RCT715 arrived today.
The radar component is excellent, the video download process is bloody awful.
I pair with it and it takes a few minutes to download and drops out halfway through most of the time. I'm assuming most people just plug it into a PC via the USB cable?
Postby jasonc » Sat Mar 02, 2024 7:20 am
Yep. Just plug the thing in. The app is horrible. I've only used the app for configuration
Mr Purple
Postby Mr Purple » Sat Mar 02, 2024 9:01 am
The app is absolute trash. I have no idea how a multinational corporation thought they could get away with releasing that rubbish.
Did a 27km ride on a major road to work today. Three notable bits of footage (Dodge Ram doing a deliberate narrow pass, another SUV running through the shoulder at me and an idiot doing well over the speed limit through a red light). But now I'm at work and the only way I can download any of that is via the app. Which doesn't work. The stupid thing is you can't even lock the footage from the app so it doesn't get rewritten later which you would have thought was the most important feature the app could actually have.
Radar is excellent at least. And I'm pretty sure the change in flash pattern made some drivers realise they were being filmed - that's actually less drama than I usually have on a ride to work.
warthog1
Postby warthog1 » Sat Mar 02, 2024 9:15 am
Hmm, I am an IT numpty, just not interested, so I will struggle.
You must be able to do it somehow, as JasonC regularly posts footage from his.
Yes the radar without the camera also changes flash pattern. I get quite a few sitting behind me waiting until it is safe to pass. I am guessing some may mistake it for a camera due to its' size.
I always wave my thanks when they wait.
