ICAN X-Gravel build thread - another journey !
Re: ICAN X-Gravel build thread - another journey !
Postby warthog1 » Wed Apr 26, 2023 10:44 pm
- MichaelB
Postby MichaelB » Thu Apr 27, 2023 8:01 am
Will look at the small-small option next time I size the chain. But is the issue then that the big-big may not have enough chain ?
For me, I would be more like to inadvertently go big-big rather than small-small.
Anyway, onto todays dilemma
After thinking I managed to snaffle a great price on aDT G1800 wheelset to be used for gravel, only realised too late (already shipped) that I ordered the 27.5” version, not the 700C version that I have recently purchased tyres for…….
DOH !!!
Not a major issue in the end, but something I didn’t need as then need to get the relevant matching stuff.
That’s what you get when ordering stuff late at night on a phone !?!
Anyone after some 38mm Gravelking Semi slick Plus TLC tyres ….
Postby warthog1 » Thu Apr 27, 2023 9:28 am
I did small/small on my gravelly. It will still run 48-36 if you want to.
- MichaelB
Postby MichaelB » Tue May 09, 2023 2:14 pm
I’ve got three separate parcels in Aus (MTB pedals from Taiwan, wheelset & tyres from Bike24 and tyres from R2 Bike) that seem to be taking forever to get anywhere and really slow updates from the AP system.
The Pedals were on their way from Sydney to Adelaide on Friday 9:45am and still no update ….
And the weather, house build stuff and work is keeping me off the bike atm.
PFBB
- MichaelB
Postby MichaelB » Tue Jul 25, 2023 1:53 pm
Another dead rear rim ....
Picture of each side.
Managed to limp to work with multiple CO2 topups (tyre is tubeless)
Postby warthog1 » Tue Jul 25, 2023 3:13 pm
Hope you can get it repaired/replaced soon Michael
- MichaelB
Postby MichaelB » Wed Jul 26, 2023 9:55 am
The cheap set of R470’s I bought are now on the ICAN with some Continental Urban 35’s.
Llewellyn now has the 52mm Konax Pro back on.
End plan will be to cannibalise the front rim from the Hunt wheelset and rebuild as a rear for a windy day set for the Llewellyn. But that’ll take a few weeks.
- MichaelB
Postby MichaelB » Thu Oct 12, 2023 9:30 am
Well, finally some progress on the ICAN rear wheel. The rims got delivered a few weeks ago, but busy with work, house stuff and riding, so finally managed some time yesterday arvo to dismantle the FUBAR'd rear wheel, clean the hub and spokes, and start reassembling into the new Carbonal D21-22 rim.
The pre-assembly involved two critical checks - 32 holes and ERD being the same .....
2 outta 2 !
A quick check of the Muson's wheel building guide, and lacing was initiated !
Lacing went fine and the next step is now to tension and true ! (might be a week or two to get done !)
One thing that surprised me, was that the damaged rim was still pretty strong despite the size of the crack. Will have a closer look and cut it up a bit, but pleasantly surprised !
- MichaelB
Postby MichaelB » Thu Oct 19, 2023 9:01 am
Mounted the Challenge Bianca Pro tyres onto the recently purchased G1800 wheelset (bargain from Farceberk marketplace) and the TLR one was a sod to get on, but wasn't as hard as the other wheelset. They are now ready for the new 11-36 cassette on it's way and for the gravel rides around Mintaro at the end of October !
I then also finished truing/tensioning the repaired rear wheel with the Carbonal replacement rim (Thanks Duck! for the recommendation of Carbonal !) and then installed the rim tape and swapped over the 35mm GP Urban tyres onto them from the R470 rims. Mounted them on the bike and didn't even need to adjust the caliper alignment. SWEET.
The R470 rims will now be sold, as they are surplus to requirements.
- MichaelB
Postby MichaelB » Tue Oct 24, 2023 10:22 am
The wheelset is DT Swiss G1800, tyres are still the Challenge Bianca Pro in 40mm, and now wearing an 11-36 cassette (giving a 32-36 low gear) and have a new chain fitted- one of the e-bike chains I got from MTB direct a while ago at a bargain price
Riding the combo to work over the next couple of days to make sure all is well and adjusted right prior to hitting the dirt.
Hopefully the wind stays away this weekend, weather is good so will hopefully have some shots to share next week
Postby warthog1 » Tue Oct 24, 2023 10:41 pm
- MichaelB
Postby MichaelB » Fri Nov 17, 2023 8:51 am
Solved that by getting a new GRX810 crankset (farceberk) for $200, GRX FD from Fleabay and then a few weeks ago got a GRX RD as still using a road Ultegra long cage. The BB was snaffled from Pushys with the SHIM20 discount - had to settle for the Ultegra, as the DA one was sold out , but still, at $32.99 - 20% and shipped free (bought a couple of rotors as well).
That change will probably come over the Xmas break, so will flog off the Praxis crankset and the near new rings for whatever I can get for it.
Then the bike will be complete ....
Postby LondonGravel » Mon Dec 04, 2023 9:01 pm
I’ve got the same frame and am now in the process of building it up. I’ve got some Qs about the gear cable routing. Would be great if you could help please.
How far do you run the mechanical gear cable outers inside the frame?
I see you ran them from the BB plastic gear guide to the RD. So did you run inner cables from when the outers go into the frame to the BB for both RD and FD?
Thanks in advance!
- MichaelB
Postby MichaelB » Tue Dec 05, 2023 8:29 am
The outers don't go in the frame, they stop at the cable entry doodads and then run the inners from there.LondonGravel wrote: ↑Mon Dec 04, 2023 9:01 pm
Yep.LondonGravel wrote: ↑Mon Dec 04, 2023 9:01 pmI see you ran them from the BB plastic gear guide to the RD. So did you run inner cables from when the outers go into the frame to the BB for both RD and FD?
Enjoy and post some pics and details of your build in a thread.
Postby LondonGravel » Sat Dec 09, 2023 10:54 am
- MichaelB
Postby MichaelB » Tue Apr 16, 2024 11:47 am
hmmmmm
Luckily, about 3 years ago, bought a pair of exactly the same bars and had them stored safely. Winner-ish .... Also found a broken rear spoke, so fixed that as well, and will replace the front brakepads as they are getting close to worn.
But no bartape in my stock of goodies, so rode the Llewellyn to work and will pick up some on the way home.
- Duck!
Postby Duck! » Tue Apr 16, 2024 8:44 pm
Postby warthog1 » Tue Apr 16, 2024 8:49 pm
In the dumb cyclists and pedestrians thread. A car.
- MichaelB
