I recently purchased an Orbea Gain M30 electric pedal assist bike. I have set it up for gravel riding with a pair of Vittoria Terreno Dry tubeless tyres.
It's my first eBike and comes to me as a result of my health issues, namley permanent vestibular damage and cervical spinal misalignments which (long story short) cause me severe migraines when my body stresses and tires from excess physical exertion especially the muscles along my spine and under my scapulas.
I have been considering a pedal assist bike for over a year before I took the plunge. My intention was to have a pedal assist bike to extend my 90 minute limit in the saddle to half and eventually full day rides, albeit at very gentle pace.
I've owned the Orbea Gain for just 3 weeks and ridden it just over only 150km in just 4 rides, however, the early results are so far, so good.
The Orbea Gain concept is a road bike based model that offers modest pedal assist up to 25km/hr in a package that looks essentially like a contemporary road bike with a full Shimano 105 groupset, a 40 Nm Mahle X35+ compact rear hub based assist motor and a small 250Ah Mahle battery hidden in the lower end of the downtube. The motor offers three levels of assist which can be custom tuned via the Mahle phone app.
The bike weighs approx 12.8kg (size m carbon monocoque frame) with it's heavy duty Fulcrum e-Racing 400 wheelset and fitted with pedals, cages saddlebag and tools etc and I am able to easily ride it without pedal assist over tarmac up to moderate gradient rises and on gravel roads up to light gradients.
The Mahle x35+ motor is a 250 watt motor offering just 40Nm of torque - a fraction of what contemporary mid mount motor drives offer. However because the Gain is considerably lighter weight than mid mount motor models the idea is to offer just enough pedal assist to take the edge off the ride effort and so far I've found this to be largely spot on.
I rode up a 250m long 23% gradient last weekend using the highest level of pedal boost and found the assist level still perceptible but insufficient to make the climb a cake walk with me having to pedal at perhaps 85% of my ability with huffing and puffing but not nearly as much as riding my previous unassisted road bikes up the same hill. However, I did notice that once the gradient flattened out to 15% after the deadly 250m long section that the pedal assist took half the effort out of the climbing.
This is where the Orbea Gain shines. Pedaling along flats or steady gradients up to 12-14% it's considerably easier to maintain progress even with 40mm wide tyres at low pressure. Because I've been riding on very familiar loop rides near home that I've covered on conventional bikes countless dozens of times, I've observed that riding the Gain using lowest level of assist I can avoid dropping to the small ring up front in several locations, instead maintaining my cadence and remaining on the big ring on a respectable sprocket out back. This is precisely what I wanted to have at my disposal - modest power assist esp. on the run home so I don't tire and create too much tension in my upper spinal cord.
Thus far I've generally ridden the Gain on loop rides only - no long distance one way or return trips as yet but that is my goal, 100km+ long rides in a day over the Otway Ranges and beyond. My modus operandi thus far has been to ride to approx half distance without the motor assist and ridden back home using the first two levels of motor assist. I've twice managed to break past my previous 90 minute ride time limit with the last ride a 44km long mixed gravel/tarmac ride that saw me spend 135 mins actual riding time. I've not had a migraine since I've owned the Gain and so far my progression to longer rides has been a success.
In coming weeks I intend to retro fit the gain with some flared gravel bars as I find riding in the drops with a slight flare a near perfect alignment of my scapulas - riding with my elbows jutting out a bit really suits my body and I'm also swapping out the the 100mm stem for a 90mm to get the reach right where I like it. I'll update this post occasionally as I have more impressions and achievements to report.
Orbea Gain M30 - Initial Impressions
- open roader
Postby open roader » Mon Feb 20, 2023 10:32 pm
Re: Orbea Gain M30 - Initial Impressions
Postby gsxrboy » Tue Feb 21, 2023 7:46 am
100km (prob a bit less) will be pretty much it if there's any real climbing. My commuter is a D31 and when I did a gravel ride around a heritage trail (mainly in full boost on the up) 400mtrs elevation change and 50km made it a challenge to complete on a (poss) 80% charge. These days I commute with no power, and might kick it on again when I'm, completely exhausted from lack of sleep etc. So far no electric use for a few months.
- apatheticaf
Postby apatheticaf » Mon Oct 02, 2023 7:29 pm
I learned something, as I was confused why they didn't go for a mid drive. Curious whether you test rode any mid drives and how they feel in comparison to your Orbea Gain? (I'm considering an Orbea Vibe)open roader wrote: However because the Gain is considerably lighter weight than mid mount motor models the idea is to offer just enough pedal assist
- open roader
Postby open roader » Tue Oct 03, 2023 10:03 pm
Since this post I have reverted my Orbea Gain back to a road bike and purchased a Giant Trance X Adv E+ Elite MTB which I have modified into a gravel road bike.apatheticaf wrote: ↑Mon Oct 02, 2023 7:29 pmI learned something, as I was confused why they didn't go for a mid drive. Curious whether you test rode any mid drives and how they feel in comparison to your Orbea Gain? (I'm considering an Orbea Vibe)open roader wrote: However because the Gain is considerably lighter weight than mid mount motor models the idea is to offer just enough pedal assist
Rear hub drive and mid drive motor bikes are very different beasts.
The Gain literally provides sufficient pedal assist to take the sting out of prolonged hills, it is so light weight - that is all that you need. I have now learned to set the Gain assist level as desired, leave it on all the time and when I drop below 25km/hr the assist kicks in making lighter work of it. I ride hill and dale loop rides like this without using much battery power at all because I'm essentially riding the Gain like a normal road bike but receiving pedal assist when I'm unable to keep the pace up which is usually steeper inclines or into strong headwinds. I get a decent workout but my body not tire like it did giving me dire migraine issues.
The modified Giant mid mount drive bike has more than double the torque of the Gain and can provide pedal assist up to 400% of your own pedalling input. It packs a potentially powerful boost and can make pedalling virtually effortless but it does drain the battery very quickly when used like this. To the Giant, I fitted gravel tyres, upped the chainring to a larger cog, removed the dropper post and fitted a Canyon suspension post, switched in a swept back pair of handlebars, and fitted some cheap mud guards to convert it into a dual suspension flat bar gravel cruiser. It's a marvelous bike, weighs only 17.1 kg with lights full bottles, pedals etc. It is far more comfortable over all roads than the Gain and has fully programable via phone app. motor assist levels. I ride this bike manually switching the pedal assist on and off as required - I only use the two lowest assist levels and both of those are set to use minimal battery power giving me sufficient battery range to comfortably cover circa 100km.
The Gain is much better as pure road bike. The gravel roads I ride on are a mixed bag of smoother hard pack right through to choppy loose rubble logging tracks. A road bike fitted out with higher volume tyres just does not cut it - too jittery and too hard on my contact points. The lower pedal assist of the rear hub drive is much better suited to road use and the bike's relative light weight still makes it a close match in handling and response to riding a regular road bike.
