Carbon Hardtail XC
Carbon Hardtail XC
Postby Arbuckle23 » Thu Aug 24, 2023 2:16 pm
Thinking a Carbon Hardtail XC might be the go.
Mainly roadside tracks on the Mornington Peninsula, of which there are plenty.
Had a alloy dually prior to the gravel bike, which was heavy (you can tell I'm a roady) and overkill for the riding I was doing.
The gravel bike is fine, but I don't have the bike handling skills to feel comfortable on the slight rougher stuff on it.
What do we recommend for an old bloke doing that? The N+ 1 can't cost too much though or the boss will be very unhappy with me. Although just getting any N+1 will cause trouble
Re: Carbon Hardtail XC
Postby am50em » Thu Aug 24, 2023 4:06 pm
In stock
https://www.giant-bicycles.com/au/xtc-advanced-29-2
Postby Arbuckle23 » Fri Aug 25, 2023 10:25 am
I have checked out the Polygon Syncline range and on the surface they look OK. But reviews seem sparse.
There are a couple of Youtubers that have the C3 and seem very happy with them.
Only really negative I can see is the 27.2 seatpost. I have read it compromises fitting dropper posts because of the thin wall needed in the drop meaning you can get binding. And the 27.2 cost is more.
$1600 for the C3 is a nice price.
Postby Arbuckle23 » Mon Sep 04, 2023 12:33 pm
The N+1 will be an ally dually and will keep the gravel bike for gravel roads
- Mububban
Postby Mububban » Fri Sep 22, 2023 10:34 am
Arbuckle23 wrote: ↑Mon Sep 04, 2023 12:33 pmFlipped and flopped.
So did you buy a short travel XC dually? What did you end up with?
Postby Arbuckle23 » Fri Sep 22, 2023 11:02 am
Got mates rates with from my local bike shop, the owner is is a bloke I ride with all the time.
Very happy with it so far, although early days.
Only little issue is bidon size. On the medium the space is very small so I need to find a bidon less than 600 mm to the top, will have to measure a 500ml to see whether that is small enough.
I still have a hydration pack from last time I owned a MTB so not that big an issue.
But a warning for others to note
Postby blizzard » Fri Sep 22, 2023 11:09 am
Is that using a side entry bottle cage?Arbuckle23 wrote: ↑Fri Sep 22, 2023 11:02 amBought a Merida 120 600.
The 120 600 looks like great value for that XC / light trail bike.
Postby Arbuckle23 » Fri Sep 22, 2023 11:14 am
The smaller bidons I have can jam in but don't sit straight.
Hopefully get down to the shop today so I can measure.
I thought about trying to lower the cage, but the clearance on the shock is close as it does stroke through an arc.
- Mububban
Postby Mububban » Wed Sep 27, 2023 4:11 pm
In hindsight, that's the model I should have purchased, instead of the 140 400. I'm a roadie who occasionally dabbles in gravel and MTB, so the short travel 29er would have bene a better fit for my riding. Live and learn!
Postby Arbuckle23 » Wed Sep 27, 2023 7:24 pm
- Mububban
Postby Mububban » Thu Sep 28, 2023 12:03 pm
Arbuckle23 wrote: ↑Wed Sep 27, 2023 7:24 pm
Exactly my use. Just looking for a bit of a diversion from the road.
They may look like peak 90s, but consider some bar ends if you're planning on doing some >2 hour gravel rides. After becoming used to my drop bar bike, those long flat sections of non-treacherous gravel really become uncomfortable on my MTB flat bars, without different hand positions.
Postby Arbuckle23 » Thu Sep 28, 2023 1:30 pm
Still got the gravel bike. Long gravel rides will still be on that.
This bike is for the rougher roadside tracks around here. Can still take a couple of hours, but the MTB is needed for me as the bike handling skills are not up to it on these tracks on a gravel bike.
Went out last weekend for a couple of hours, will most likely head out again tomorrow for a MTB ride, Public Holiday in Vic
- bychosis
Postby bychosis » Thu Sep 28, 2023 6:30 pm
Postby Arbuckle23 » Thu Sep 28, 2023 10:02 pm
But getting the dually and keeping the gravel bike is an option I am glad I decided to do.
- bychosis
Postby bychosis » Fri Sep 29, 2023 4:49 am
Postby Arbuckle23 » Thu Jan 11, 2024 1:04 pm
To answer my question, to help others, because this thread comes up now when you search bidons to fit a Merida 120.Arbuckle23 wrote: ↑Fri Sep 22, 2023 11:14 amYes with side entry.
I have found a bidon that fits, Zefal Sense Pro 50 500 ml bottle that measures 161 mm to the top of the cap.
Not cheap, but fits perfectly.
