Identifying this "Shimano Racing Components" bike
dave_cyclist
Postby dave_cyclist » Wed Nov 29, 2023 1:50 pm
Hi all, I have this "Shimano Racing Components" bike and I would appreciate some help in further identifying it as I haven't been able to find any information about it online. Maybe it was a one off track type bike by Shimano? Here is the information I have been able to get off the components:
Shimano 6 speed cassette freewheel: Shimano SIS MH: August 1988 VIA MF-Z012 Japan
Suntour Cyclone cranks: LP, CC: March 1986
Shimano RX100 front derailleur: 1992, TF: June 1995
Suntour Accushift 4050 rear derailleur: EC: March 1988
Brakes: Dia Comp
Levers: Dia Comp Aero
Gears front 52/42
Gears rear 13-23
Frame: Tangealoy which puts it around the Repco Eurosport Tri-A spec
Weight: 10.8 kg
Pictures attached.
Thanks very much in advance Dave :)
https://flic.kr/p/2pix7sm
https://flic.kr/p/2piqWiy
https://flic.kr/p/2pixL82
https://flic.kr/p/2pivsmk
https://flic.kr/p/2pixLcR
https://flic.kr/p/2pixLck
https://flic.kr/p/2piwx15
https://flic.kr/p/2pivssT
https://flic.kr/p/2pivstu
https://flic.kr/p/2piwx1L
https://flic.kr/p/2pixLhk
Re: Identifying this "Shimano Racing Components" bike
Postby familyguy » Wed Nov 29, 2023 2:03 pm
It's likely a generic Shimano sticker pack applied to what looks like a reasonably nice frame. Looks nicely built. Longish chain stays, the bottle bosses under the downtube and double rear eyelets indicate it was probably aimed at touring. No serial number on BB shell or seat tube?
It's a good size, for once. Either it's a really long seat tube (65c/c?), or it's way off square (64x58 or something?)
dave_cyclist
Postby dave_cyclist » Thu Nov 30, 2023 12:26 am
Hello, no serial number that can be seen unfortunately, thanks for the information though :)
elantra
Postby elantra » Thu Nov 30, 2023 10:30 am
The Italian-made mid-1980’s Europa frames usually did not have any serial number on the frame.
But as far as I know the Europa Italian frames do usually have the frame size in cm stamped under the bottom bracket.
As yours appears to be a fairly large frame then look for a “61” stamped under bottom bracket.
However if it made from Tangalloy tubing then it’s very unlikely to be an Italian frame.
That is unless the Tangalloy sticker is just an add-on, like all those Shimano stickers.
Anyway it looks like a nice frame.
Most of the running gear on it, especially the Suntour and RX100 bits do work extremely well with a little TLC.
The gear ratios however are not very hill-friendly !
dave_cyclist
Postby dave_cyclist » Thu Nov 30, 2023 4:43 pm
Hello, thanks again, as you can see I had a look on the bottom of the bb and unfortunately no frame number, only scratches which I thought were the number at first. Maybe it's in a slightly different postion? And I got the Tangealloy designation from the fact that the headset nut has Tange on it, maybe only the nut is Tange? Again as you may be able to see the Text from left to right on the nut says: Japan, Pat. P (which I'm guessing is patent pending), Tange. And with the gear ratios I find that this original cluster works better for me up the hills than other more mountain bike lower geared clusters I have and have tried on it. I find the slower more constant pedalling suits me better than the spinning higher and getting more out of breath lower ratios and I get to the top of Mt Cootha and Mt Gravatt much more refreshed than on the other gear ratioed clusters :) And it also helps that I go slightly further for each pedal stroke being slightly higher gear ratioed :) So would the final verdict be a Japanese or Italian frame in your opinion? Thanks Dave :)
https://flic.kr/p/2piJeSr
https://flic.kr/p/2piJeRQ
https://flic.kr/p/2piLxVL
https://flic.kr/p/2piJeRE
https://flic.kr/p/2piLxVF
elantra
Postby elantra » Thu Nov 30, 2023 10:27 pm
I don’t really know.
Actually in one of your pictures there appears to be water bottle mounting points UNDER the frame tubing (downtube).
This suggests that it is a Touring frame.
Touring bicycles with 3 mounting points for water bottles were the bees knees in the 1980’s.
If it is one of these it’s more than likely Japanese built or local (Australian) custom build.
Probably the latter - because the Japanese and Taiwanese love to put serial numbers on their bike frames !
And I get what you are saying about the gearing.
I am not a fan of “spinning” the legs - also known as high cadence. But I concede that it can be very effective for some people.
Back in the late 1980’s I used to do Coottha on a Repco Vertex with 42 tooth inner chainring and 6-speed 13-24 cogs on the back.
For climbs like Coottha if you are young and fit then 42 x 24 is going to be very effective.
dave_cyclist
Postby dave_cyclist » Thu Nov 30, 2023 10:56 pm
Thanks again Elantra for the interesting information! :) So when you say "bee's knees" would it indeed be equivalent to the Repco Eurosport Tri-A or your Repco Vertex? And by the way my Repco Superlite (which you may have seen posted by me previously, it;s the white and green bike) had original gearing which I still have of 52/40 and 14-24 so close to that 42/24, just slightly lower. But this Shimano goes like a floating guided missile vs the Superlite which feels like a jet ski/speed boat powering through the waves by comparison. I put that down to the Shimano being 1. taller so my legs extend more, 2. lighter and 3. it has the old fashioned toe clips on the pedals as you may have seen. Thanks Dave :)
Postby familyguy » Fri Dec 01, 2023 9:35 am
These two photos show an interesting detail. The downtube appears to be flared out once it emerges from the bottom bracket, around the bottle boss area. Assuming it's not massively kinked and it is a flare in the tube, this would be a detail that might give some indication as to origin. Can't say I've come across that before.
dave_cyclist
Postby dave_cyclist » Fri Dec 01, 2023 11:26 am
Hi familyguy yes either an early attempt at aero or a manufacturing technique? Maybe it is indeed an Australian custom build as Elantra was saying :)
dave_cyclist
Postby dave_cyclist » Fri Dec 01, 2023 11:28 am
And that same flare is at the other end as you may see from the other photos so I think it's designed that way :)
Postby familyguy » Fri Dec 01, 2023 11:40 am
So it is, looking closer at some of the photos. Intriguing.
Does it sound/feel like they've got a bigger tube sleeved over a more standard tube for that length? Have you taken the bottle cage bolts out and had a look to see long the threads inside run for? Might give another clue as to whether it's a single tube been shaped or a sleeve added for endurance/strength.
Certainly increasingly looking like a custom build. It's clearly for a tall person, so perhaps the builder went fully custom and beefed it up for a lot of weight.
dave_cyclist
Postby dave_cyclist » Fri Dec 01, 2023 1:35 pm
Hi familyguy, no it doesn't feel any different than a standard diameter tube, when I did remove bolts for inspecting them and fitting bottle cages etc it didn't notice they were any different in length to the ones on the Superlite so it may be a single custom shaped tube. And so do you reckon the guy got assorted high end parts and the Shimano stickers and put them all on to make it like a Tour de France bike? Thanks Dave :)
Postby familyguy » Fri Dec 01, 2023 1:55 pm
The sticker packs were widely available through shops, maybe they repainted it and just whacked them on cause a plain bike wouldn't sell. It's reliable and nice without being sporty or expensive, just a neat bike that you should ride a lot.
rkelsen
Postby rkelsen » Sun Dec 03, 2023 11:39 am
Nope. As others have said, it's a generic sticker set. And definitely not a track frame.
With that said, it does have some interesting features. It does look like a custom build. The long chain stays and 3rd bottle mount would suggest that it was built for touring. Longer stays would prevent heel strike with panniers.
There's only 2 cable holders on the top tube. Mass-produced bikes almost always had 3, although I did have a Raleigh that had 2. Colnago used to do 2, but that's definitely not what this frame is.
The flared downtube is weird. Never seen that before!
You seem to be riding it with the seat quite low. Is it too big for you? Can you stand over the frame without going soprano?
dave_cyclist
Postby dave_cyclist » Sun Dec 03, 2023 2:37 pm
Thanks for the extra information, I can just get on it, it allows the greatest leg extension of all my bikes as previously stated :)
rkelsen
Postby rkelsen » Mon Dec 04, 2023 1:30 pm
If the seat as pictured is at the right height for your leg length, then that frame too big for you.
DernyDriver
Postby DernyDriver » Mon Dec 04, 2023 3:14 pm
Agree.
Need to be about 6'10" or 6'11" to ride that bike :shock:
dave_cyclist
Postby dave_cyclist » Sat Jan 06, 2024 8:59 pm
Here are some more photos of both the Shimano and Superlite, please enjoy! :) ImageIMG_20240101_211054 by Dave R, on Flickr
ImageIMG_20240106_141308 by Dave R, on Flickr
ImageIMG_20240106_142918 by Dave R, on Flickr
ImageIMG_20240101_211654 by Dave R, on Flickr
