Friction shifters with 11 speed
- open roader
Postby open roader » Tue Dec 05, 2023 3:56 pm
Concept of debate (and likely ridicule) :-
Running an 11 speed derailleur and cassette on a retro frame using friction shifters.
Can it be done? Can it be done simply?
If you ask "why?" I counter with "why not?" I've built up a lot of bikes in mostly conventional ways and I find myself pondering left field topics - let's call it a minor mid life crisis..........
Despite the countless hours I've burned reading up on all sorts of bicycle related matter I'm yet to see 11 speed friction shifting attempted or offered for sale. Infact 9 speed is where it seems to mostly have stopped being a 'thing'.
My guess is insufficient cable pull on the shifter lobes to get the derailleur across all 11 cogs but I don't know this for certain.
Any input most welcome.
Re: Friction shifters with 11 speed
Postby warthog1 » Tue Dec 05, 2023 4:07 pm
https://velo-orange.com/products/dia-co ... t-shifters
•Designed for 11 speed, but will work with fewer speeds
•Better option for 10 speed drivetrains than our other Dia-compe levers
•Friction (non-indexed), micro ratchet design
•Right barrel is larger than the left for more cable pull
Installation with 11speed ultegra r8000, mid-cage and VO 46-30 crankset. Works really well! The front derailleur was a bit more complicated to set up
http://www.diacompe.com.tw/product/ene-11s-shifter/
Postby NASHIE » Tue Dec 05, 2023 4:18 pm
- familyguy
Postby familyguy » Tue Dec 05, 2023 4:42 pm
- P!N20
Postby P!N20 » Tue Dec 05, 2023 6:01 pm
open roader wrote: ↑Tue Dec 05, 2023 3:56 pmI'm yet to see 11 speed friction shifting attempted or offered for sale.
Alex Steida runs 11 speed friction:
- Duck!
Postby Duck! » Tue Dec 05, 2023 9:25 pm
The main issue isn't cassette width, it's that (presuming Shimano parts) 11-sp. derailleurs need a longer cable pull to cover a given shift distance due to a different actuation ratio. Obviously indexing isn't a concern, but most friction shifters won't have sufficient stroke to move an 11-sp. derailleur across a full cassette.familyguy wrote: ↑Tue Dec 05, 2023 4:42 pmI would think that if you can get 10s SIS/indexed, that it can be done. The range of travel is the same, more or less, I wouldn't think the added gear and minor difference in cassette width would suddenly render it unworkable. I've got a 10s clicky SRAM TT lever as a bar end, with one spare that I was going to de-index to run as a friction bar end on something. Maybe I try 11s instead?
SRAM use a common actuation ratio for road/MTB 10-sp + road 11-sp, but is different from everything else (but is pretty close to Shimano road 11-sp.)
- familyguy
Postby familyguy » Wed Dec 06, 2023 9:16 am
True, a bit of both. Purely talking outside widths, a 10s cassette is 37.2mm (via Sheldon), 11s cassette is 40.1mm. Shimano 11s have a 1.4 ratio, so a 2.9mm shift requires another c.2.0mm of cable pull. Might not quite get it with a friction shifter.Duck! wrote: ↑Tue Dec 05, 2023 9:25 pmThe main issue isn't cassette width, it's that (presuming Shimano parts) 11-sp. derailleurs need a longer cable pull to cover a given shift distance due to a different actuation ratio. Obviously indexing isn't a concern, but most friction shifters won't have sufficient stroke to move an 11-sp. derailleur across a full cassette.familyguy wrote: ↑Tue Dec 05, 2023 4:42 pmI would think that if you can get 10s SIS/indexed, that it can be done. The range of travel is the same, more or less, I wouldn't think the added gear and minor difference in cassette width would suddenly render it unworkable. I've got a 10s clicky SRAM TT lever as a bar end, with one spare that I was going to de-index to run as a friction bar end on something. Maybe I try 11s instead?
Postby warthog1 » Wed Dec 06, 2023 2:12 pm
This says it is designed for 11 speed.familyguy wrote: ↑Wed Dec 06, 2023 9:16 amTrue, a bit of both. Purely talking outside widths, a 10s cassette is 37.2mm (via Sheldon), 11s cassette is 40.1mm. Shimano 11s have a 1.4 ratio, so a 2.9mm shift requires another c.2.0mm of cable pull. Might not quite get it with a friction shifter.Duck! wrote: ↑Tue Dec 05, 2023 9:25 pmThe main issue isn't cassette width, it's that (presuming Shimano parts) 11-sp. derailleurs need a longer cable pull to cover a given shift distance due to a different actuation ratio. Obviously indexing isn't a concern, but most friction shifters won't have sufficient stroke to move an 11-sp. derailleur across a full cassette.familyguy wrote: ↑Tue Dec 05, 2023 4:42 pmI would think that if you can get 10s SIS/indexed, that it can be done. The range of travel is the same, more or less, I wouldn't think the added gear and minor difference in cassette width would suddenly render it unworkable. I've got a 10s clicky SRAM TT lever as a bar end, with one spare that I was going to de-index to run as a friction bar end on something. Maybe I try 11s instead?
There is another link I put up earlier, where in the feedback, people had run it successfully with shimano 11s
- familyguy
Postby familyguy » Wed Dec 06, 2023 2:26 pm
I missed that. Simple solution, very cool. The bigger diameter rear shift lever implies more cable is pulled, easy!warthog1 wrote: ↑Wed Dec 06, 2023 2:12 pmThis says it is designed for 11 speed.
Postby warthog1 » Wed Dec 06, 2023 5:45 pm
Makes you wonder if you could run an 11 speed cassette with any old derailleur using those levers? An 11s 11-34 will fit on a 10s hub but don't know what 10s derailleurs will clear a 34? Don't need to use that cassette if you have an 11s freehub on your wheel thoughfamilyguy wrote: ↑Wed Dec 06, 2023 2:26 pmI missed that. Simple solution, very cool. The bigger diameter rear shift lever implies more cable is pulled, easy!warthog1 wrote: ↑Wed Dec 06, 2023 2:12 pmThis says it is designed for 11 speed.
Don't know if the range of an 8, 9 or 10s derailleur would let it shift far enough?
I expect an 11s chain should still be ok on older derailleur pulleys?
Anyway makes me wonder what you could achieve with older stuff, but I am no expert, hopefully Duck or somebody else knows how it may go. More gears and range is always good.
- Duck!
Postby Duck! » Wed Dec 06, 2023 8:39 pm
It's for this reason the 11-sp. actuation was reduced to 1.4. it makes the derailleur less sensitive to small adjustments, therefore easier to tune.
With the limits backed out, most derailleurs have enough travel to cover an 11-sp. cassette, however only veey recent road models have the capacity to handle 30+ T sprockets; to go bigger you need to look at the MTB family.
Postby warthog1 » Wed Dec 06, 2023 9:54 pm
Sounds like it would be a pita to shift accurately then.
- Duck!
Postby Duck! » Wed Dec 06, 2023 11:22 pm
Easier to quote and respond separately than splice into mo my previous related post....familyguy wrote: ↑Wed Dec 06, 2023 9:16 amTrue, a bit of both. Purely talking outside widths, a 10s cassette is 37.2mm (via Sheldon), 11s cassette is 40.1mm. Shimano 11s have a 1.4 ratio, so a 2.9mm shift requires another c.2.0mm of cable pull. Might not quite get it with a friction shifter.Duck! wrote: ↑Tue Dec 05, 2023 9:25 pmThe main issue isn't cassette width, it's that (presuming Shimano parts) 11-sp. derailleurs need a longer cable pull to cover a given shift distance due to a different actuation ratio. Obviously indexing isn't a concern, but most friction shifters won't have sufficient stroke to move an 11-sp. derailleur across a full cassette.familyguy wrote: ↑Tue Dec 05, 2023 4:42 pmI would think that if you can get 10s SIS/indexed, that it can be done. The range of travel is the same, more or less, I wouldn't think the added gear and minor difference in cassette width would suddenly render it unworkable. I've got a 10s clicky SRAM TT lever as a bar end, with one spare that I was going to de-index to run as a friction bar end on something. Maybe I try 11s instead?
Shimano's long-running standard derailleur actuation is 1.7:1. Most friction shifters will be designed to this ratio. So using the quoted cassette width figures, a 37.2mm wide cassette with a 1.7 derailleur wants a total cable pull of 21.9mm. The same cassette with an 11-sp. or related very recent Tiagra /GRX400 1.4 ratio derailleur needs a 26.6mm cable pull. That's a 4.7mm difference in pull on the same cassette.
Jump to an 11-sp. cassette at (quoted) 40.1mm overall width. As noted previously, most older derailleurs should have enough adjustability to cover the extra distance, but cable pull really comes into play here. a 1.7 derailleur needs a 23.6mm cable pull to cross the cassette. A 1.4 derailleur needs 28.6mm cable stroke to cover the cassette. The vast majority of friction shifters are "geared" - excuse the unintended pun - to a 1.7 pull ratio, so although have a little bit of overshift capacity will be hard pressed to find an extra 5mm of cable pull to work a 1.4mm derailleur the whole way across the cassette; it's quite a bit more lever arc to find that 5mm of cable, and that's where the 11-sp.-compatible shifters Warty linked previously fit in.
- baabaa
Postby baabaa » Fri Dec 08, 2023 7:02 pm
https://www.microshift.com/models/bs-a11/
Have run dura ace 10 speed bar end shifters on most of my bikes which you can "shift" between friction and index - never tested on / as 11 speed (even though most of the hubs are 11 speed) in friction or index
The sportive bike is running dura ace 11 speed on 11 speed hubs but a 10 speed cassette - can only run these in index
Also a run 10 speed microshift bar end shifter but set up as thumbies for flat bar - same, only run as 10 speed but on wider range cassette and much touring /bike packing lower front chain rings
All above are 2x and I consider microshift as good if not better to run - just get the microshifts.
- DavidS
Postby DavidS » Sun Dec 10, 2023 11:44 pm
DS
- Duck!
Postby Duck! » Mon Dec 11, 2023 11:33 pm
Users browsing this forum: Amazon [Bot]
