New front light for daytime riding to fit GoPro mount
Postby DennisEdwards » Thu Dec 28, 2023 3:05 pm
Using bike for medium to long (up to 6 hours) day time rides like 100km - 150km or the Classics. Front lights are mandatory for Classics.
I have a Garmin Edge so I'll get (probably) a K-Edge combo ihs mount, so now all I need is a front light which is GoPro mount compatible.
Someone mentioned to me Knog Blinder 900 but seems to be MTB.
Thanks for the recommendations.
- g-boaf
Re: New front light for daytime riding to fit GoPro mount
Postby g-boaf » Thu Dec 28, 2023 8:03 pm
DennisEdwards wrote: ↑Thu Dec 28, 2023 3:05 pmLooking for headlight recommendations as overwhelmed by options.
I like the Serfas e-Lume 1750 and have a specific mount rigged up to a combo mount (not K-edge but similar). I have to say I like the support from Serfas as well, I had an older e-Lume light which had bad batteries, I could order replacements and fit them easily.
It should be fairly easy for you to fit those e-Lume lights, they have a particular mount available for the job.
Postby am50em » Thu Dec 28, 2023 8:11 pm
Postby warthog1 » Thu Dec 28, 2023 9:37 pm
https://road.cc/content/review/giant-re ... 100-279275
It comes with a garmin mount to run under the computer mount.
That is where I run mine.
- Retrobyte
Postby Retrobyte » Sat Dec 30, 2023 1:10 pm
Specifically, the https://ravemen.com/FR/FR160.html - then you don't need a GoPro mount at all - just attach your Garmin to the inbuilt mount on top and you're set. On low/medium or flashing you get 6 hours of light plus.am50em wrote: ↑Thu Dec 28, 2023 8:11 pmTake a look at the https://ravemen.com/ range. Need the optional adapter for GoPro mount. They have cut off lens that can be rotated when you mount upside down.
- g-boaf
Postby g-boaf » Sat Dec 30, 2023 1:51 pm
Even the Serfas e-Lume lights all have slightly different clips to connect them - even though they look similar.
Postby nathg » Sat Dec 30, 2023 2:00 pm
- grt046
Postby grt046 » Sat Dec 30, 2023 6:52 pm
Run it on Day Flash on all day rides and combined with Garmin Varia rear radar/tail light am all set
Postby DennisEdwards » Sun Dec 31, 2023 3:36 pm
In the meantime, has anyone looked at the Varia? I have the Varia rear radar so maybe a good combo?
https://www.garmin.com/en-AU/p/550821
Postby caneye » Tue Jan 02, 2024 1:24 pm
The elastic will hold any cylindrical-shaped light.
https://www.aliexpress.com/item/1005006 ... ouSCijlssI
- g-boaf
Postby g-boaf » Tue Jan 02, 2024 1:56 pm
I was able to disassemble the top of the Garmin mount and underneath it has holes for screws/bolts. The bolts are slim enough to fit in the small gap then I can screw the go-pro mount to that. Then the light just has a go-pro adaptor.
I cannot take credit for that neat installation, it was my very clever local bike shop mechanic who is a wizard with things like this. Then I copied his work for the S5.
Not sure the performance specs on that light are the greatest. Only 1.5h?DennisEdwards wrote: ↑Sun Dec 31, 2023 3:36 pmThanks for this. I'm now researching the Ravemen and the required mounts and brackets.
Compare this: https://www.serfas.com/shop/products/li ... headlight/
That lasts a lot longer in case you are doing long rides at night. Something else I recommend is having a backup light with you just in case your main one fails.Solid Mode:
Overdrive 1750 Lumens – 2 hrs
High 1000 Lumens – 3.5 hrs
Medium 700 Lumens – 6.5 hrs
Low 400 Lumens – 9 hrs
Flash Mode:
Daytime Flash 1750 Lumens – 50 hrs
Low Flash 200 Lumens – 35 hrs
Postby warthog1 » Tue Jan 02, 2024 3:14 pm
I cannot see it under my Garmin edge.
Runtime: High (1100LM) 1.5hrs,
Middle 3.5hrs (500LM),
Low 7hrs (275LM),
Smart Mode Day (100LM>275 LM) 36hrs;
Smart Mode Night (500LM) 3.5hrs,
Flash (100 LM) 33hrs
- Retrobyte
Postby Retrobyte » Tue Jan 02, 2024 3:25 pm
The Ravemen FR160 doesn't need a mount. The light fits your Garmin mount, and your Garmin clips into the Garmin mount on top of the lightDennisEdwards wrote: ↑Sun Dec 31, 2023 3:36 pmThanks for this. I'm now researching the Ravemen and the required mounts and brackets.
- MattyK
Postby MattyK » Wed Jan 03, 2024 10:23 am
If you want a good beam, my new favourite is the Lightskin Nacaroad headlight. It might have enough runtime for you in low mode (and it will still have enough lux to see where you’re going), but yeah battery life is a limitation if you want to go far. (Though it can run off an external battery pack)
- Retrobyte
Postby Retrobyte » Wed Jan 03, 2024 5:14 pm
OP said "Using bike for medium to long (up to 6 hours) day time rides like 100km - 150km or the Classics. Front lights are mandatory for Classics."
- MattyK
Postby MattyK » Wed Jan 03, 2024 11:20 pm
The 1000+ lumen possum fryers mentioned in this thread are a different ballgame and totally unnecessary for daytime road riding.
Postby Andy01 » Thu Jan 04, 2024 10:50 am
The Moon Mizar that I had before was a supposed 100 lumens on the daylight flash but it was such a quick/short flash that it wasn't very "visible" at all - I was using it when a SUV rounded a corner without looking and took me out head-on if that tells you anything.
If it is just to "tick the box" for a organised ride, then the 160 is probably OK, but it isn't really a "be seen" option in my opinion.
- g-boaf
Postby g-boaf » Thu Jan 04, 2024 2:04 pm
Personally I wouldn't want to be just ticking the box, I'd prefer a light that you really know will be seen and will have enough life left in it when the sun goes down so you can see where you are going, if you get in that situation.Andy01 wrote: ↑Thu Jan 04, 2024 10:50 amHaving said that, the "slow flash" of the RM160 is only 50 lumen (8 hour life), which is pretty pathetic and won't really be seen in brighter daytime conditions. Even my Cateye Ampp 400 flashes between 200 and 400 lumens and is not very bright on a sunny Brisbane day.
Mine can be very bright, but I rarely use it on full brightness. Even on it's mid level, that's enough and also decent battery life. If the battery should fail, it's nice that you can buy replacement batteries rather than throwing away the entire light.
Postby warthog1 » Thu Jan 04, 2024 4:13 pm
Not much worth stealing here but thanks
Postby Andy01 » Fri Jan 05, 2024 10:24 am
I agree. Within reason (I wasn't about to spend hundreds of dollars on a 1000+ lumen light knowing that I will never ride at night) I think the brighter the better and IMO less than 300-400 lumens for a front light is a waste of time for daylight use. My Ampp 400 gives me about 7 hours when set on the option where the 200 lumen is on continuously and the flash is 400 lumen - and from memory it cost me less than $50.g-boaf wrote: ↑Thu Jan 04, 2024 2:04 pmPersonally I wouldn't want to be just ticking the box, I'd prefer a light that you really know will be seen and will have enough life left in it when the sun goes down so you can see where you are going, if you get in that situation.Andy01 wrote: ↑Thu Jan 04, 2024 10:50 amHaving said that, the "slow flash" of the RM160 is only 50 lumen (8 hour life), which is pretty pathetic and won't really be seen in brighter daytime conditions. Even my Cateye Ampp 400 flashes between 200 and 400 lumens and is not very bright on a sunny Brisbane day.
But, as above, if it is just to make the event organisers happy, then I guess anything would do.
