The Big Wet
g-boaf
Re: The Big Wet
Postby g-boaf » Wed Jan 31, 2024 11:16 pm
mikesbytes wrote:
Tue Jan 30, 2024 9:54 pm
Adding to the split vs ducted debate. In my situation it would be difficult but not impossible to locate 4 split systems outdoors, one bedroom in particular. The one large outdoor system is a bit of bother as it is though.
I have a large ducted system and agree with the person before even running just in fan mode helps a lot. On hot days with the whole thing going it quickly lowers the temperature and keeps it low.
I’ll see myself out before the off-topic police shout at me (and you). ;)
warthog1
Re: The Big Wet
Postby warthog1 » Thu Feb 01, 2024 11:05 am
I like going off-topic, bugger it, I'm in. :lol:
Luckily enough it doesn't get that humid here. Roof top evaporative does the job and low current draw. New pads a couple of years back, made from some sort of honey comb material. They work well. I bought a new fan motor the year before and installed it myself.
Have a new water pump sitting in the shed if that carks it. The main problem will be if the control box in the unit dies, they are hard to find and expensive I believe.
One of the young fellas my son plays footy for has a dad with a plumbing business. He knows a contractor who specialises in evap aircons who is reasonably priced. :)
Heating is the bigger problem here. Wood fire sorts that, as Gas is prohibitively expensive, now that it has been sold off into private hands :roll:
Andy01
Re: The Big Wet
Postby Andy01 » Thu Feb 01, 2024 5:05 pm
robbo mcs wrote:
Wed Jan 31, 2024 7:38 pm
Ducted systems are getting a bit of a bad rap on here, not all deserved.
The thing about then sucking warm air in the inlet is a bit of furphy. The air circulates from the high pressure area (rooms with outlet vents) to a central low pressure area with the inlet vent, usually in a hall. Normally the area where the vent is only 1-2C warmer than the rooms with outlet at the most, more often the same temperature. It is not like you are sucking it from 40C outside. So if you are just running a zone in one room, then it is only cooling that room and the hall.
Ducted generally is more efficient at keeping temperatures even within a room and across the house.
Also generally quieter than a split, talking about the air circulation, not the compressor which is the same.
The other thing about ducted systems is they are very efficient at equalising temps and spreading cool or warm air, even when not used in heating or cooling mode, just with the fan. So if you have a hot half of the house facing west, and a cool half facing east, you can run in low speed fan mode, and equalise the temps, even without running the compressor.
The modern ducted control systems are generally extremely flexible, and tend to offer a lot more fancy remote access options and smart control systems than splits
I have a house with ducted, and a holiday place with splits. I travel a lot, and stay in a lot of accomodation mostly with splits. I would rather have ducted any day for a house, unless it is tiny. A small apartment, then split is probably just as good
I absolutely agree about ducted being a less "obstrusive" system to use.
In my situation over the last few weeks in Brisbane, I have had temperatures inside the house of up to 32° and 70% humidity in the early evenings (the western side gets a bit hotter than the eastern side).
Typically I will turn on my 5kW split in my lounge room around 7pm, and run it until about 10pm. It is set for 25° (and gets there within about 30 minutes if it starts around 29°). The rest of the house is still at 29-30°.
Then around 8:30pm I will start my bedroom 3.5kW unit and set it to 20º (to drop the humidity as low as possible - it gets there from 30° in about 75 minutes). The rest of the house is still at 27-29°.
Then at around 10pm, the loungeroom unit goes off and the bedroom unit is set to 23° where it stays all night (it tends to "over-cool a touch and be around 21-22° at 6am the next morning).
Recently the temps in the rest of the house at 6am (when the bedroom unit is turned off) is between 25-28° and "sticky" with the outside humidity around 90-100%. For weeks now we have had "feels like" temps of over 30° at 7am due to high humidity & dew points. Also in times of sustained high temps (where it doesn't cool much overnight) the house insulation tends to get saturated after a few days, and if anything tends to trap heat inside overnight.
So, in my situation I can have 5°(or more - and that is after the initial cooldown which has closer to 10° difference) difference between our main bedroom & ensuite (under 40m²) and the rest of the house. If I had a ducted system the return vent would probably be in the main hallway and I would have to cool at least 120-140m² as (like most houses) it is fairly open plan and has a long U-shaped hallway that runs right around the house to the kitchen & family room. I would also have to close off the doors to the other bedrooms, study, laundry & longeroom which would get annoying doing that daily. Even though the area with the return vent wouldn't be set to cool to 23°, it would be seeing some cooling from the "high pressure" air being pushed back out under the bedroom door. What may, of course, be even more of a concern is the amount of that "high pressure" air that the ducted system is blowing into the bedroom is escaping through the ensuite extractor fan into the roof space (which I obviously don't want to pay to cool).
That is why I said above that choice between ducted & splits is a personal one that depends entirely on the design of the house and the needs / makeup of the people living there (and the location). If the house has good segregation (ie. doors that can be easily closed), and several rooms are being used simultaneously (like multiple bedrooms being used) and/or the house is in an area (perhaps like Perth) where things tend to cool down more obviously at night, or the humidity effect is less, then ducted may well be a better choice.
But if the cooling is for primarily people sleeping in one or two bedrooms (which is the impression I got from the poster who first mentioned getting AC, and I think he was in Brisbane, like me), and the location is in a high humidity area where the temperature doesn't drop much at night, then splits may be a better choice. In this situation I would wager that running 1-2 splits in bedrooms would consume a fraction of the electricity of running the ducted system all night.
Anyhoo, yes we have got off track a bit, so I will shut up now :oops:
Andy01
Re: The Big Wet
Postby Andy01 » Thu Feb 01, 2024 5:25 pm
Back on track - with January now wrapped up, I have recorded 392mm of rain in Jan'24, which is the highest January rainfall since I built the house in 2002. This is more than half of the 768mm we got over the whole of 2023 (we got 88mm in Jan'23).
Jan'11 (Brisbane flooded) - 312mm
Jan'12 (Brisbane & Logan flooded) - 358mm
Jan'13 - 322mm
They were the only other years (in the last 22 years) over 300mm. The poor buggers in Brisbane's north western suburbs copped up to 300mm in 3 hours a couple of nights ago and significant flooding resulted. Apparently Suncorp, AAMI & NRMA has all suspended starting new home insurance policies, so I can see our premiums doubling (or close to) again this year.
And it seems that we have the 3rd potential cyclone (since Christmas) brewing off the Qld coast so the supposedly "dry" summer isn't finished yet. On today's newsfeeds there are photos & stories of widespread flooding over much of Qld's regional western areas (outback), and predictions of over 300mm still coming in many areas from Mt Isa and southwards.
elantra
Re: The Big Wet
Postby elantra » Fri Feb 02, 2024 12:04 am
392 mm rain for the month just completed (January) !
About 100 km south (as the crow flies) Murwillumbah got 670 mm - yikes !
In terms of average rainfall statistics, February is the wettest month of the year, as it is in Brisbane.
Hopefully this February will not be unusually wet or dry. But it’s out of my control !
The average annual rainfall for Brisbane varies a little bit according to what suburb, but is mostly a bit more or less than 1100 mm.
Murwillumbah is significantly “wetter” with an average annual rainfall of 1500 mm.
According to BOM, the “wettest” town in NSW is the town of Mullumbimby, which is not much further to the south, inland from Byron Bay and Brunswick Heads (which are also pretty wet)
Mullumbimby (better known as Mullum to the local people) has an average annual rainfall of almost 2,000 mm.
But there are parts of North Queensland that have significantly higher annual rainfall than this amount.
Places like Babinda, Tully, Millaa Millaa, Kuranda all have average annual rainfalls in excess of 2,000 mm.
In fact, the average annual rainfall in Tully is reputed to be approximately 4,000 mm per year !
foo on patrol
Re: The Big Wet
Postby foo on patrol » Fri Feb 02, 2024 8:34 am
People might like to have a look at things like this recorded history before jumping up and down about rain. Like I've said before, people just don't do proper research before buying house/land but are quick to jump up and down and blame others for their problems in flood zones. Then you have areas being affected now with flooding that wasn't flooded back in 74, because of development of surrounding land that has had natural waterways blocked/filled in inadequate pipe sizes for drainage and land being built up metres higher that stops water flow and backs it up till it finds it's own escape points. :idea:
https://www.slq.qld.gov.au/blog/brisban ... ollections
https://www.slq.qld.gov.au/blog/1974-be ... remembered
https://www.environmentandsociety.org/m ... g-brisbane
Foo
Goal 6000km
MichaelB
Re: The Big Wet
Postby MichaelB » Fri Feb 02, 2024 9:52 am
MichaelB wrote:
Mon Jan 08, 2024 9:22 am
Oct 2023 - 11.6mm rec'd, vs 44.1mm average (25% of normal)
Nov 2023 - 60.6mm rec'd, vs 31.1mm average (double average)
Nov 2023 - 73.4mm rec'd, vs 25.8mm average (triple the average)
Jan 2024 - 13.6mm rec'd (to 8th Jan), vs 20.0mm average for the month
So, before going back OT, I'll help with the strayers and go off OT for a bit.
We just got our ducted Evap/Condensor replaced - the compressor carked it after 23 off years of fault free service. The new unit (same brand and capacity) works SOOOOOOO much better than the old one. Holy dooley.
Anyway, back on track, and with normal-ish summer weather returning to Adelaide, we still had well above average rainfall for Jan
Jan 2024 - 61.2mm rec'd, vs 20.0mm average (just over triple the average) - we even had one day where we got 34.8mm in the day !! (yep, I know you northerners and Sydney siders can get that in 15 min .... :roll:
And our rainwater tanks are still full !
Andy01
Re: The Big Wet
Postby Andy01 » Fri Feb 02, 2024 4:13 pm
:lol: :lol: :lol: We got 123mm on New Year's Day :lol: :lol: :lol: My rainwater tank has been overflowing since November - garden hasn't needed water and pool hasn't needed topped up.
Is the ducted Evap/Condensor system a refridgerated AC or the evap units that seem to be common in the south ? I think there is quite a big difference between them, and from what I have seen the evap units don't work well in humid climates with high dewpoint temps - obviously fine for the "dry" heat in Vic & SA though.
warthog1
Re: The Big Wet
Postby warthog1 » Fri Feb 02, 2024 4:27 pm
They are hopeless when it is humid.
15 years in Alice and most of it with evap aircon. Toward the end though it was getting more humid with more days when it struggled.
Further North and they weren't widely used as just not effective.
Re: The Big Wet
Postby Duck! » Fri Feb 02, 2024 7:50 pm
I haven't been tracking rainfall numbers, but here in Melbourne we haven't had anything noteworty since the two thumping downpours in early January. We have had some more rain, but mostly just fairly light sprinkles. Temps have also been pretty mild, only occasionally nudging the mid-30s. Overall it seems to be a cooler summer than average, and aside from those two big dumps, pretty normal as far as rainfall. Certainly not resembling the El Nino cycle that was predicted.
brumby33
Re: The Big Wet
Postby brumby33 » Fri Feb 02, 2024 7:53 pm
When we moved down to Albury and moved into the house we bought, we had one of those ducted evaporative cooling systems which most houses have them here as a standard fitment, we turned ours on and it smelt awful, we spoke to a lot of people about these thing because we had no previous knowledge of them and we had some say that in the event of bushfires and Smokey air outside, you need to close the vents as the smoke will go right through everything in the house, and my wife has quite some respiratory issues so we elected to get it disconnected and capped off and we installed the biggest split system unit we could, about 9.5kw cool and 11.5kw warm or something like that.....it's a big bugger sitting at the back of the house and not really that noisy. We have a long hallway from the rear to the front door and it's powerful enough to keep the majority of the house cool. I love it!!
I just got back from 6 days in Sydney just this arvo and the humidity in Sydney was unbelievable compared to here in Albury, I was sweating continuously up there the past few days, I don't remember Sydney being that Humid and I've lived there for the best part of 35 years.
I agree with Foo, when people buy houses, especially in a town that has a reputation for flooding, they don't tend to do enough due diligence that could spare them a lot of heartache later on. So many people were buying houses sight unseen from the internet.....bloody crazy if you ask me.
Before we bought in Albury, we went to the council office and got them to print out maps of previous record floodings in the all areas including issues with large water drains which can be overcome easily in heavy downpours and when we bought this house, while not the Ritz Carlton by a long shot :lol: we are confident that our property is not subject to any major water issues except a little running water along the back fence that comes from next door on one side and goes through to next door the other side.....no biggie.....although I have seen water streams going down our street on the road but it heads down towards the T-intersection...not sure if those houses cop it or not...but it's a result of some flash water streaming in very heavy rain and not a result of waterways......but these are things one must be away of and can only try and protect yourself the best you can by buying in a good area. Any area can be affected in unprecedented storms and rain bursts but those charts & maps can help select the better streets.
VWR Patagonia 2017
brumby33
Re: The Big Wet
Postby brumby33 » Fri Feb 02, 2024 8:05 pm
I was watching a weather report on ABC TV last week (they have much better reports than commercial stations) and they are saying that this El-Nino will be short lived and we still have a negative di-pole over the Indian Ocean, and they are also saying there's a good chance that another La-Nina developing towards the end of this year and if the Indian Dipole doesn't become positive, we could be in for a lot more unsettled weather next Summer. Our grounds are saturated now after 3 full years of wet weather, it doesn't take much for more flooding.
brumby33
VWR Patagonia 2017
am50em
Re: The Big Wet
Postby am50em » Fri Feb 02, 2024 8:08 pm
Sydney is always very humid, mid January to mid March. A good time to travel to get away from it!
mikesbytes
Re: The Big Wet
Postby mikesbytes » Fri Feb 02, 2024 9:29 pm
What's happening with the Murray delta, has it got enough rain to fill up the rivers and lakes?
brumby33
Re: The Big Wet
Postby brumby33 » Fri Feb 02, 2024 11:25 pm
Well currently Mike the Hume Dam is at 84% capacity, wouldn't take much to fill that up with a few weeks of decent rain.
I remember just before the big wet started at the end of those horrific bushfires in early 2020 around the time Covid also hit, the Warragamba Dam was under 40%, water restrictions were in and within 3 weeks, the dam levels had more than doubled, then with weeks onwards, it was at capacity so yeah they can fill up quickly with the right conditions.
Along the Murray river system as it stands today, the ground is so wet, it can barely absorb any water now, especially from Echuca and down through the Goulburn River systems.
Probably Warty could give you more current update as his area of Bendigo has had a lot of rain recently with those storm bands going right across the state of Victoria. We didn't get much of it at all in Albury and there was no river rises in around town.
Because I'm new to this region, I've really only learnt that the river systems actually run North and is why Towns like Rochester and Echuca become Compromised. The river systems run completely opposite to how they do on the Coast as I've experienced in my time up at Grafton (Clarence River) and the Hunter Valley where they flow Eastward to the sea.
VWR Patagonia 2017
MichaelB
Re: The Big Wet
Postby MichaelB » Sat Feb 03, 2024 11:22 am
Is the ducted Evap/Condensor system a refridgerated AC….
Refrig AC/Heating
Andy01
Re: The Big Wet
Postby Andy01 » Sat Feb 03, 2024 11:51 am
Refrig AC/Heating
23 years is a great run for a AC compressor.
mikesbytes
Re: The Big Wet
Postby mikesbytes » Sat Feb 03, 2024 1:30 pm
The humidity this big wet is enhancing must make dehumidifying more attractive. Anyone using the dry function quite a bit?
Re: The Big Wet
Postby jasonc » Sat Feb 03, 2024 3:06 pm
The dry function is cheap to run and does drop a couple of degrees off the temp. I use it a lot
warthog1
Re: The Big Wet
Postby warthog1 » Sat Feb 03, 2024 3:53 pm
Rochester is built on a low point on the Campaspe river. In 2022 Lake Eppalock was full the Murray (which is basically a series of small dams) was also full. A big rain in the Campaspe catchment meant a full Eppalock couldn't hold back the flow and the Campaspe was unable to drain effectively as the Murray it drains into was also chockers. Basically the whole town went under.
The flooding just recently was escaped by Rochester just. Many have had enough though and are selling their houses as is. It will definitely flood again.
Just rode over Eppalock again today. It is full. They don't have any mechanism to release water quickly out of Eppalock and they still hang onto the water as irrigators may need it. :roll:
Tim
Re: The Big Wet
Postby Tim » Sat Feb 03, 2024 4:38 pm
Here in Eastern Victoria we've not had anything much in rainfall since early January. Much the same as Duck's comments on Melbourne, although still very humid.
The countryside has gone/is going from an English looking, long, lush green rolling pasture to a more typical summer's parched brown condition.
The grasses dry out very quickly and the bush not far behind. At least the soil is still holding moisture but a dry February will put us back to "normal'" summer appearances. With a bit of luck nothing will catch fire.
brumby33
Re: The Big Wet
Postby brumby33 » Sat Feb 03, 2024 6:50 pm
Yes we're starting to get the very dry hot days but the early morning temps arn't bad at the moment and still very sleepable.
We look to get some rain maybe Monday/Tuesday but that could change quickly, the lawns need a bit of a drink and I'm too tight to turn on the hose :mrgreen:
It's usually quite warm here till nearly MAY when it cools down a bit through the day, it's the best time to ride either Bicycle or Motorcycle here.
I'm going to start riding my bike to work again and usually by the time i'm finished, any traffic is gone.
It's my last day of 2 weeks off tomorrow so I might get up early and go for a bit of a ride into town, coffee perhaps if anything is open, and get home before the heat of the day sets in, 38C tomorrow in Albury with 33% Humidity forecasted then maybe a storm later in the evening. (maybe)
brumby33
VWR Patagonia 2017
g-boaf
Re: The Big Wet
Postby g-boaf » Tue Feb 06, 2024 5:10 am
Big wet is back again, steamy and pouring rain, at least in Sydney.
mikesbytes
Re: The Big Wet
Postby mikesbytes » Tue Feb 06, 2024 12:22 pm
Not enough to truly get rid of all of yesterdays heat, hopefully I'm wrong and it won't be humid tomorrow
elantra
Re: The Big Wet
Postby elantra » Tue Feb 06, 2024 12:25 pm
That’s interesting, I believe it’s got somewhere to do with the ex- cyclone Kirrilly (or so it’s said in the media)
Meanwhile up here at the mouth of the Clarence River - only 500 km north of Sydney as the crow flies - it’s very sunny and very hot, but not quite as hot as Brisbane is, 300 km to the north.
