Di2 shifter compatibility with brake hoses
- open roader
Postby open roader » Sun Feb 18, 2024 9:44 pm
I have a bike fitted with a 105 11 speed mechanical disc groupset. My hands are battered from 35 years of abuse. I find it uncomfortable, bordering painful pushing the Shimano brake levers laterally to shift gears. I can do it effectively but the discomfort really detracts from the ride to the point where I occasionally just alter cadence forsaking another gear shift.
Ideally I'd like to convert this bike to Campagnolo H11 EPS as I love thumb shifters and the electric shifting requires just a tap of the levers but these groupsets are few and far between.
I rode a friend's bike fitted with 10 speed Di2. The hoods are still very long but the electric shifting is considerably easier for my hands, particularly my left hand.
I'm now considering if it's a simple thing to convert my 11speed 105 mechanical disc to 11 speed Di2?
In particular can I leave the current internal routed brake hoses in situ and simply swap over / bleed a pair of Di2 disc shifters? Might be a deal breaker if it's that straight forward.
- Duck!
Re: Di2 shifter compatibility with brake hoses
Postby Duck! » Sun Feb 18, 2024 10:48 pm
Postby kilroy » Mon Feb 19, 2024 8:24 am
- biker jk
Postby caneye » Mon Feb 19, 2024 11:09 am
but will need a pair of DI2-hydraulic 11s shifters, DI2 cables, junction boxes, 2x derailleurs, battery, charger.
good thing is ..there are many 11s DI2 parts in the used market.
can't go wrong.
also check this website if you have any questions re mixing of DI2 components ..
https://bettershifting.com/di2-compatib ... omponents/
Postby kilroy » Mon Feb 19, 2024 12:44 pm
My 11 speed Ultegra 8070 shifters have the button.
Postby CmdrBiggles » Mon Feb 19, 2024 2:11 pm
Ah, so! That's what it is?
I haven't seen this button on a recent test ride of a GIANT TCR running ULTEGRA. If per chance there are variations, is the button hidden under the hood? Granted I have seen, somewhere at some time, a lever/button sticking out of the inboard side of levers. Is this what is being referred to?
- MichaelB
Postby MichaelB » Mon Feb 19, 2024 2:58 pm
caneye wrote: ↑Mon Feb 19, 2024 11:09 amalso check this website if you have any questions re mixing of DI2 components ..
+100 to the above site. It's brilliant.
- Duck!
Postby Duck! » Mon Feb 19, 2024 5:56 pm
The extra button is hidden under the rubber hood cover, on the flat section at the peak of the shifter. Dura-Ace Di2 shifters have always had it, but it didn't get to Ultegra until the R8050/8070 models. By default the buttons are programmed to do stuff on compatible computers via Bluetooth connection (requires a wireless transmitter unit plugged into the wiring harness) but can be reprogrammed through the E-Tube software to become additional shifters.CmdrBiggles wrote: ↑Mon Feb 19, 2024 2:11 pm
The sticky-outy lever you've previously seen would be the cable release (upshift) trigger on older low-end series Sora and 2200/2300, forerunner to what is now named Claris. None of the Di2 shifters have had sticky-outy levers/buttons on the inboard side. Campagnolo's EPS equivalent does have them.
- Duck!
Postby Duck! » Mon Feb 19, 2024 6:03 pm
105 Di2 is part of the very different 12-sp. family and mostly incompatible with previous stuff, so not even worth mentioning in the context of this thread.
- Duck!
Postby Duck! » Mon Feb 19, 2024 6:05 pm
Or just ask me....MichaelB wrote: ↑Mon Feb 19, 2024 2:58 pmcaneye wrote: ↑Mon Feb 19, 2024 11:09 amalso check this website if you have any questions re mixing of DI2 components ..
Postby CmdrBiggles » Mon Feb 19, 2024 7:19 pm
But I digress...
I fiddle with my SRAM Force eTap shifters using SRAM's AXS app on android.
At this time I have not got a Wahoo 'puter that keeps track of what the drivetrain and shifters do; there is a limit to how much one can sensibly spend in one hit before stepping back for a Navy-strength gin and lamingtons to plot the next cashectomy!!
Postby davehirst » Mon Feb 19, 2024 9:44 pm
Surely it would be navy strength rum
- MichaelB
Postby MichaelB » Tue Feb 20, 2024 8:48 am
And what a great resource and patient explainer of the wonderful world of Shimano !!Duck! wrote: ↑Mon Feb 19, 2024 6:05 pmOr just ask me....MichaelB wrote: ↑Mon Feb 19, 2024 2:58 pmcaneye wrote: ↑Mon Feb 19, 2024 11:09 amalso check this website if you have any questions re mixing of DI2 components ..
Postby CmdrBiggles » Tue Feb 20, 2024 10:16 am
Nup. Not a rum drinker!
Postby davehirst » Wed Feb 21, 2024 9:43 pm
- open roader
Postby open roader » Mon Feb 26, 2024 2:47 pm
I assumed a 2nd hand Campagnolo H11 EPS groupset would be a more expensive option than some 2nd hand Di2 parts and by a considerable margin, however, after looking at the prices asked for 2nd hand Di2 (both Ultegra and DuraAce offerings) it seems to me that the cost may be on par or Campagnolo may be cheaper OMGosh
Either way I'll have to remove the pedal assist down tube battery from the frame so fiddle wise both options are similar - Campag being slightly more fiddly with new hydro lines having to be installed.
- MichaelB
Postby MichaelB » Tue Feb 27, 2024 9:11 am
Qualifier : I have no experience with EPS.open roader wrote: ↑Mon Feb 26, 2024 2:47 pm..........this was all in aid of avoiding me going for my plan A which was to switch the current 105 11sp to Campagnolo H11 EP$.
However, on Weight Weenies Forum, there are many posts of the scarcity of spares for EPS (chargers, batteries etc) so would be REALLY careful with buying a s/hand EPS, v1 or 2 for that very reason.
May also be a leader/reason as to why the value of the items is less.
Good luck whatever you do, but yet, Di2 parts seem to be really pricey !
Postby caneye » Tue Feb 27, 2024 4:19 pm
I've been able to pick up used 11s DI2 groupsets for $600-800.
Have you seen used SRAM AXS groupsets?
They make DI2 look like a bargain.
- open roader
Postby open roader » Tue Feb 27, 2024 8:36 pm
I've just started looking - need to be patient..........
Postby CmdrBiggles » Wed Feb 28, 2024 9:05 am
Apples and oranges. It does depend on what you want in terms of performance and function.caneye wrote: ↑Tue Feb 27, 2024 4:19 pmI had a look at used EPS groupsets a while back. Yes, the prices are comparative to used DA DI2 groupsets. I put it simply to the lack of demand for EPS. Also notice that they take a long time to sell.
SRAM has never been a bargain buy, never when it was first into road, nor more broadly into MTB.
The SRAM AXS has an especially wide range of tuning available via the app — moreso than the Shimano. A lot of time can be squandered at coffee stops stepping through so many available tweaks and features! There is a major update in the works scheduled for the SRAM app that takes tuning even further (late-April?).
Postby caneye » Wed Feb 28, 2024 1:58 pm
oh .. i never view SRAM that way. It was always just another alternative to DI2.CmdrBiggles wrote: ↑Wed Feb 28, 2024 9:05 am
interesting that others view it differently. it's probably me
- g-boaf
Postby g-boaf » Wed Feb 28, 2024 8:29 pm
I don't know about others, but I wonder how many used SRAM AXS group sets would be out there?
Mine is running fine so I have no need to sell it.
In any case, they are a means to get somewhere - so I don't get how some treat it almost like a religion. One of my bikes has Shimano cranks, another one has Di2 (the TT bike), two of them SRAM E-Tap (11 and 12 speed) and some of my other bikes have older mechanical Dura Ace 9000.
The only thing I haven't done is got into those Italian groupsets (or Italian bikes).
Anything groupset related or bike components now is crazy expensive. From any of the brands.
- Duck!
Postby Duck! » Wed Feb 28, 2024 11:04 pm
Maybe it's one of the reasons that I''m now ex-industry.... I never understood why people would fork out Megabucks to replace stuff that functions perfectly, and often more than adequately for the particular rider, for no other reason than it's not the Current Sh...tuff.
I got up my former boss's nose on numerous occasions for having the audacity to actually fix stuff rather than just chucking new bits on....
