Wonky Front Wheel Movement
Ali Ba Ba
Postby Ali Ba Ba » Fri May 24, 2024 12:51 pm
Hi All,
New bikie (is that even a term? I don't know) here.
Removed my front bike wheel in order to patch the tube. When I replaced it, the wheel rolls in a funny way.
The wheel is attached by a thru-axle quick release system (bruh, I had to look that up). I might or might not have tightened it enough, or tightened it too much. I don't know.
Here's a video of the front wheel spinning wonkily. [shareyoutube]https://youtube.com/shorts/rDAqSM6RSy0?feature=share[/shareyoutube]
Any thoughts?
am50em
Re: Wonky Front Wheel Movement
Postby am50em » Fri May 24, 2024 1:06 pm
Tyre not seated in rim fully?
P!N20
Postby P!N20 » Fri May 24, 2024 4:02 pm
Wheel needs truing
foo on patrol
Postby foo on patrol » Fri May 24, 2024 8:14 pm
Yep, the wheel is in need of some work. :idea:
Foo
Goal 6000km
CmdrBiggles
Postby CmdrBiggles » Sat May 25, 2024 2:30 pm
Hi All,
Any thoughts?
• deflate the tyre; grip the tyre with your hands squeezing both sides as you work around it, to seat the tyre bead in the rim;
• inflate the tyre until it is soft, but not flat;
• repeat the first step above, again working right around the rim;
• inflate until the tyre is firm to touch, and slowly eye the tyre right around the rim to ensure it is seated;
• if all goes well with that previous step, inflate to full pressure.
Other causes:
• Possibly the QR is not securely closed
• Nuts securing the hub bearings on one or both sides have worked loose
GIANT '24 TCR Adv. Pro Disc 0-AR/ SRAM Force eTAP | 2022 Dragon Raptor e-scooter ['Yellow Peril']
Ali Ba Ba
Postby Ali Ba Ba » Sun May 26, 2024 8:34 am
Wheel needs truing
Thanks @P!N20! Looked it up. Looks like a process. Will take my time to work through it.
Found this. https://www.bikeradar.com/advice/worksh ... ue-a-wheel
Ali Ba Ba
Postby Ali Ba Ba » Sun May 26, 2024 8:35 am
Foo
Thanks @Foo for id-ing the issue!
How do I mention/tag names?
Ali Ba Ba
Postby Ali Ba Ba » Sun May 26, 2024 8:38 am
Thanks am50em. Noted.
Ali Ba Ba
Postby Ali Ba Ba » Sun May 26, 2024 8:41 am
Hi All,
Any thoughts?
Other causes:
Thanks so much CmdrBiggles. Appreciate the detailed rundown. Will action this soon and let you all know how it goes!
foo on patrol
Postby foo on patrol » Sun May 26, 2024 10:42 am
Foo
I don't know that you can on this platform. :?:
Foo
Goal 6000km
