Do you still have this bike? If you are in Melbourne I will gladly take it off your hands!ausbikemad wrote: ↑Fri Jun 21, 2019 9:10 pmHi all
I have a 1990 Prairie Breaker Team issue in really good condition I'm thinking of selling,
it has the white, green & purple paint scheme. only non original parts are the saddle, tyres & grips
what do you think is a fair asking price
Shogun Appreciation Society
Re: Shogun Appreciation Society
Postby casey.h » Tue Aug 18, 2020 7:51 am
Postby ameobob » Tue Oct 13, 2020 7:40 am
I recently acquired this little guy in desperate need of some TLC. It looks to me like possibly 70s, anyone have better ideas on the year? I assume it's Shogun, but I can't find Shogun explicitly printed anywhere. All of the components have the Suntour/Maeda/DiaCompe branding, except the whole crankset which looks to be after-market, and the seat which has obviously been replaced with something hideous. These pics are in its original state, since then I've cleaned up all the componentry and re-packed the headset and bottom-bracket. Once I get it all finished I can post some follow-up pictures TIA!
Frame
Badge
Decal 1
Decal 2
BB S/N
- familyguy
Postby familyguy » Tue Oct 13, 2020 5:25 pm
Not sure it's a Shogun. Solid bike boom era stuff. The head badge is pretty cool, regardless.ameobob wrote: ↑Tue Oct 13, 2020 7:40 amI recently acquired this little guy in desperate need of some TLC. It looks to me like possibly 70s, anyone have better ideas on the year? I assume it's Shogun, but I can't find Shogun explicitly printed anywhere. All of the components have the Suntour/Maeda/DiaCompe branding, except the whole crankset which looks to be after-market, and the seat which has obviously been replaced with something hideous. These pics are in its original state, since then I've cleaned up all the componentry and re-packed the headset and bottom-bracket. Once I get it all finished I can post some follow-up pictures TIA!
Frame
Badge
Decal 1
Decal 2
BB S/N
Doesn't fit with the Shogun serial numbers as outlined here: https://www.bikeforums.net/classic-vint ... guide.html
But, some info on a 'Samurai' branded bike here, with a serial listed that matches the format of yours: https://www.bikeforums.net/classic-vint ... -what.html
Some of the parts may have date codes on them, which can be narrowed to a year. Both Shimano and Suntour do this, with date code info:
Shimano - http://www.classicrendezvous.com/Japan/ ... _codes.htm
Suntour- http://velobase.com/ViewBrand.aspx?Bran ... 9e6&From=T
Postby ameobob » Wed Oct 14, 2020 4:02 am
Brake arms - 610? 5583?
Rear Derailleur - 4532?
Rear Derailleur again - PE: May 1973?
Freewheel - PJ: Oct 1973?
- familyguy
Postby familyguy » Wed Oct 14, 2020 11:25 am
Suntour GT, seems to have only been produced 1972-1973: http://velobase.com/ViewComponent.aspx? ... &AbsPos=18
DiaCompe 610 brakes: http://velobase.com/ViewComponent.aspx? ... 7&AbsPos=4
- 10speedsemiracer
Postby 10speedsemiracer » Wed Oct 14, 2020 12:35 pm
A very small brand in the early 70s Bike boom window, although the headbadge is different to other examples. The only headbadge I've found have an image of Mt Fuji and some sort of character beneath.. The components fit though, except for the cotterless crank, which I'm guessing is a much later fitment.
That SunTour GT rear mech is a variation/of similar ilk to the SunTour Seven and SunTour Honor derailleurs and is good stuff.
A similar Atami bike :
Postby ballantynedewolf » Fri Oct 16, 2020 5:50 pm
Can anyone advise the fattest 700c tyres it will take?
I've found to my cost that it won't take 700c x 32 (32 - 622)
Postby Eug1 » Sat Oct 17, 2020 1:15 am
My '96 Katana can only fit up to 25mm tyres. I had to use a dremel to grind out some welding on the front fork to make it fit. Otherwise it would have been 23mm.ballantynedewolf wrote: ↑Fri Oct 16, 2020 5:50 pmI'm rebuilding my Katana (flouro orange, natch) which has been under the house in bits for 15 years.
- 10speedsemiracer
Postby 10speedsemiracer » Sat Oct 17, 2020 2:29 am
I've gotten 28mm Vittoria under an early 90s Samurai, but 28mm was the max. But maybe not Conti 28mm ('cos they sit fatter than 28mm).ballantynedewolf wrote: ↑Fri Oct 16, 2020 5:50 pmI'm rebuilding my Katana (flouro orange, natch) which has been under the house in bits for 15 years.
- MattyK
Postby MattyK » Sun Nov 08, 2020 8:17 pm
New tyres (Conti GP, 25c, biggest I thought would fit)
New tubes
New rim tape
New brakes (Promax dual pivot, replaced rusty single pivots)
New bar tape
New cables
New cassette (8 speed, 11-28, used to have a 12-21! We're not as young as we used to be...)
New chain
New bottom bracket
New saddle
New (old) pedals (shiny PD-5700, not shown but they look shmick)
Full cleanout of the shifters (frozen solid)
Cleaned ~20 years of grime off everything (half of that with a toothbrush)
Polished all the shiny bits. A bit of filing and sanding needed on the shifters to smooth out the crash damage.
Trued the wheels.
Didn't touch the headset or the wheel bearings as they seemed OK.
About $350 in costs (plus time and effort). Looks good in the sunshine.
- 10speedsemiracer
Postby 10speedsemiracer » Sun Nov 08, 2020 8:24 pm
Rx100 ?
I have this exact same frame, but smaller.
- MattyK
Postby MattyK » Sun Nov 08, 2020 9:00 pm
RX100 shifters.
RSX rear D.
300EX front D.
Yes he is a tall lad! 60cm frame, 195?cm rider
Postby skippa » Tue Jan 12, 2021 12:28 pm
Just posted the old Apollo I picked up on the weekend over at Apollophiles, but here is my other pickup, a 1980s (I think?) Shogun Katana triple triangle. So far have just replaced the tires and tubes and given her a clean.
Saw this pop up on Marketplace and having seen coldst's Katana looking so nice I had to grab it!
Already enjoying this bike and hoping to hold onto it, but I'm concerned about the rust spots that are present near the lugs, BB, dropouts and tubes. It all seems like surface rust but for longevity I would like to fix it up to avoid further damage.
I love the paint that's left though, so I don't really want to repaint it.
I've had a look on here for spot rust advice and I couldn't really come to a conclusion for best practice on the forum... Any suggestions?
Are these frames generally regarded as somewhat decent for the period?
The saddle seems like leather and has ITALIA on the back but I can't figure out what the brand name is.
Any suggestions appreciated! Oh, and yeah, it came with the aero bars Maximum speed maximum style right?
- P!N20
Postby P!N20 » Tue Jan 12, 2021 1:06 pm
You could drop a bit of rust converter on the rust spots then touch up with paint. That's only if you don't want to see the rust though. Another option is some fish oil on the rust spots, which should stop them getting any worse - no paint though.
Absolutely! Shogun triple triangles are quite desirable and getting harder to get in good condition (especially in that size) - so that's a good find.
That frame is a lot bigger than the Apollo which you said was a good size - is it too big?
- 10speedsemiracer
Postby 10speedsemiracer » Tue Jan 12, 2021 1:18 pm
Nice try Pinz.
- P!N20
- P!N20
Postby skippa » Tue Jan 12, 2021 2:50 pm
Thanks for the advice!P!N20 wrote: ↑Tue Jan 12, 2021 1:06 pm
It actually is on the larger side for me I think. I've dropped the seatpost a fair bit now but haven't had the chance to go on a proper ride with it yet so time will tell if it's too large (I don't have any experience with traditional bike sizing so not really sure what my baseline measurements are).
My (probably dodgy) measurements seem to indicate that the top tube is 1cm shorter than the Apollo but the seat tube is 1-1.5cm taller than the Apollo. The downtubes were extremely similar in length.
It's definitely not a perfect fit as I've got only about 8cm of seatpost showing? Hard to compare coming from a modern compact frame though. I'll just have to ride it and find out.
- familyguy
Postby familyguy » Tue Jan 12, 2021 3:07 pm
Pull the seat post and forks out and give it a inside the tubes with a torch. Pull the BB if you're concerned, that'll show you whether anything is flaking internally, it'll generally end up in the BB shell. Maybe spray some fish oil or lanolin spray inside the tubes as a preventative. You could hit those slight rut/chip spots lightly with fine steel wool (lightly!) to smooth the edges. Give it a polish with car wax for a bit of external protection.skippa wrote: ↑Tue Jan 12, 2021 12:28 pmHey all,
It looks pretty good. Compare it to my Shogun, which I didn't touch as far as external finish:
- Derny Driver
Postby Derny Driver » Tue Jan 12, 2021 10:11 pm
It has a 7 speed full groupset of Shimano 105, in my opinion one of the most functional and underrated groups ever made. So Ive put a set of Cinelli bars and stem on it, put new chain, chainrings and cluster on it (I hate worn chainsets) and some tyres and bingo, Im off and riding the thing. 3 short rides so far.
I have 25-30 beautiful bikes with all sorts of expensive components on them, but I never ride those. They're too good to ride. They are just to look at. This old Shogun looks a bit rough, but is remarkably light and rides beautifully, quite surprising really because Ive never rated Shoguns. I still dont rate them, but I like riding this one, and can appreciate it.
Hence my "review" in the Appreciation Society.
Am I a member now?
Postby rkelsen » Wed Jan 13, 2021 1:48 pm
Welcome to the dark side.Derny Driver wrote: ↑Tue Jan 12, 2021 10:11 pmThis old Shogun looks a bit rough, but is remarkably light and rides beautifully, quite surprising really because Ive never rated Shoguns. I still dont rate them, but I like riding this one, and can appreciate it.
Am I a member now?
It's nice to have a bike you can ride without being paranoid about a dint in the TT should you accidentally sneeze on it.
And you've been here long enough that I shouldn't have to say this... pics please!
- familyguy
Postby familyguy » Wed Jan 13, 2021 4:09 pm
Shogun never seemed to make many/any bikes above 60cm, so I've never owned one that fit me. I do have a Tange 2 Ninja frame hanging someplace (without the awful stock fork) that felt nicely made. Shoguns always seemed to take a nice bike, then chuck a massively fugly unicrown steel fork on all but their upper models. Their Prestige tubed models with properly lugged or sloping crown forks are really nice. Would easily outdo many Euro brands selling for similar prices. Cromor/Aelle (tretubi if you're really skint)/501 v Tange 2/1 or sometimes even Prestige? No contest!Derny Driver wrote: ↑Tue Jan 12, 2021 10:11 pmThis old Shogun looks a bit rough, but is remarkably light and rides beautifully, quite surprising really because Ive never rated Shoguns. I still dont rate them, but I like riding this one, and can appreciate it.
Am I a member now?
- Releng
Postby Releng » Sat Jan 23, 2021 3:44 pm
After some basic maintenance and a tidy up it rides nicely.
Nice condition RX100 brifters 8 speed,
- 10speedsemiracer
Postby 10speedsemiracer » Sat Jan 23, 2021 3:54 pm
Noice....
Have the same frame which was running the same driveline except for downtube shift levers, up until the crash.
Still haven't decided if I'll resurrect it..
- Releng
Postby Releng » Sat Jan 23, 2021 4:10 pm
They feel cheap and there are some big hills around here. Does anyone have any experience with them ?
