Yes I generally have the handlebar set up just as uart has described. On any (road or gravel) bike, even if it is 40 yrs old.elantra wrote: [quote=uart post_id=<a href="tel:1596025">1596025</a> time=<a href="tel:1690504484">1690504484</a> user_id=35763]
[quote=mysteriouspyro post_id=<a href="tel:1595983">1595983</a> time=<a href="tel:1690375268">1690375268</a> user_id=50621]
It's possible that the frame is a bit too small for you then. The seat post would once have had a "minimum insertion line" marked on it, but it's probably been obscured by the scuffing over time.
For a bike like that with not particularly delicate tubing, and reasonably hefty lugs, you can probably get away with a minimum insertion of 2 inches. That's a "rule of thumb" (two thumb widths actually), but it should be enough to get the seat post in past the bottom of the seat lug and beneath where the stays join it. I wouldn't go any less there for the insertion.
BTW. What's your height, and what's the frame size (seat tube length center to center)?
As uart says, if there is no minimum insertion line on the seat post then you will have to apply the “approximately 2 inches” rule. Give or take, depending.
To be honest, if you think that you need a longer seatpost this is usually one of the cheapest items on any bike to get a decent replacement for.
Kalloy brand alloy seat posts can usually be picked up for not much more than 20 dollars AU.
I think they are usually about 30cm long.
Either online or a good Local bike store will order one in for you.
[/quote]
Thanks for the reply guys- I manage to pop by a local community bike workshop and got some work done-uart wrote: ↑Fri Jul 28, 2023 10:34 amJust do whatever is comfortable for you. I tilt mine forward so that the top of bars (behind the levers) is close to horizontal, which typically puts the bottom of the bars at about 20 to 25 degrees sloping backmysteriouspyro wrote: ↑Wed Jul 26, 2023 10:41 pmAlso I just noticed everyone’s handlebar are super tilted downwards (lower end parallel to floor) on these old school bikes- do they never sit on hoods for those setup?
It's possible that the frame is a bit too small for you then. The seat post would once have had a "minimum insertion line" marked on it, but it's probably been obscured by the scuffing over time.Ah and how do you guys look for minimal seatpost length to be within the tube? There isnt any number marking per say- starting to feel my legs not really stretched out riding it.
- manage to tighten the bb, but the workshop guy said they dont have the proper thin wrench tool to tighten one side whilst holding the other nut- so will have to periodically tighten with a big wrench?
The bike has lesser play now, but it still feels abit loose in pedaling and, it starts to squeak abit when i pedal on the climb
- manage to change up the bike cable and grease it up, manage to put alittle more tension onto the lever so dont have to pull the lever too much, but ultimately still require alot more actuation on hood to get proper grip.
I also rotated back the handlebar to match what u guys recommended, much comfier for sure
Frame size is 54cm and im 183cm (on a good day hah), measure about 84cm from feet to seatbone area. Im starting to feel alot more burn on thighs and non on calves so it defo feels nqr.
Might have to pop back to the workshop to see if they have the exact seatpost size to match as the guy mentioned the seattube size changes as it ages for steel?
Also got a white spray paint- and will spray off some of the rusted area- after scrubbing it off with some al foil, pretty excited to get a start on it heh- couldnt find colour matching mango yellow unfortunatey
