Retro Handlebars And Ergolevers?
- humanbeing
Postby humanbeing » Fri Dec 30, 2011 9:30 am
Have anyone had any issues with the geometry of retro handlebars and ergolevers or sti levers? Research on the net has shown there could be problems with positioning the levers properly because of the bigger radius of the curve of the bar.
What do you think? Any recommendations for handlebars, I insist on keeping a quill stem.
Thanks for your time.
Peter
1995 Bosevski - Athena
mid/late eighties Colnago Cromor
- drubie
Re: Retro Handlebars And Ergolevers?
Postby drubie » Fri Dec 30, 2011 9:43 am
The later you go the more modern they look but they are all pretty similar in shape to plain brake levers until you get to the bent/gumby ones.
- humanbeing
Postby humanbeing » Fri Dec 30, 2011 9:58 am
2010 Athena so I guess they count as "bent/gumby", super compfy though.drubie wrote:The later you go the more modern they look but they are all pretty similar in shape to plain brake levers until you get to the bent/gumby ones.
- koen
Postby koen » Fri Dec 30, 2011 10:33 am
- drubie
Postby drubie » Fri Dec 30, 2011 8:38 pm
Comfy? Should try some of the new shape ones I suppose.humanbeing wrote:2010 Athena so I guess they count as "bent/gumby", super compfy though.drubie wrote:The later you go the more modern they look but they are all pretty similar in shape to plain brake levers until you get to the bent/gumby ones.
I had a bit of a look in my shed at the older style bars (I have some 3ttt vintage 1970s bars on a fixed gear bike) and I don't think the newer lever would present any problems, although there will be a distinct dip if the brake levers are still reachable from the drops:
A bit hard to see from that picture, but the rounded arc around to where the drops form (as distinct from the much squarer modern bars) mean a steeper run down to the drops.
If your bars are like that, likely you will have some trouble getting comfortable but it would look pretty Dali-esque and therefore cool.
edit: ah, pictures of the cinelli giro d'italia seem to indicate it's slightly squarer but also slightly steeper, so as long as you don't mind the bars not being completely horizontal at the bottom they'll work.
- Velo13
Postby Velo13 » Fri Dec 30, 2011 8:52 pm
- familyguy
Postby familyguy » Fri Dec 30, 2011 9:37 pm
Postby LoveMiyata » Fri Dec 30, 2011 10:13 pm
- brentono
Postby brentono » Sat Dec 31, 2011 12:19 pm
- humanbeing
Postby humanbeing » Sat Dec 31, 2011 3:30 pm
They tick all my boxes
- koen
Postby koen » Sat Dec 31, 2011 7:10 pm
- familyguy
Postby familyguy » Sun Jan 01, 2012 12:17 pm
Exactly what I've just put on the Gazelle, with a 110mm 1A stem. They seem to be a nice shape.humanbeing wrote:I think I might have found my solution NOS Cinelli "Touch" handlebars with anatomic bends.
Postby LoveMiyata » Sun Jan 01, 2012 7:58 pm
- toff
Postby toff » Sun Jan 01, 2012 10:00 pm
Those bars are the "Gimondi Bend" which 3TTT used on several of their models, including their track bars, and their Competizione bars. They are essentially the same shape as the Cinelli Criterium bars, but with about a cm of extra drop. I use either Gimondi bend or Criterium bars on all my bikes. The only problem you get is that the bottom of the brake levers jut out to the side a bit, as a result of the bar's curve, so it is possible to scrape the bottom of the lever when leaning your bike against a wall. Otherwise, they work better for me than any modern ergonomic bars.brentono wrote:Track Bars. Brakes?
- brentono
Postby brentono » Mon Jan 02, 2012 12:51 pm
If the shoe fits, wear it.toff wrote:Those bars are the "Gimondi Bend" which 3TTT used on several of their models, including their track bars, and their Competizione bars. They are essentially the same shape as the Cinelli Criterium bars, but with about a cm of extra drop. I use either Gimondi bend or Criterium bars on all my bikes. The only problem you get is that the bottom of the brake levers jut out to the side a bit, as a result of the bar's curve, so it is possible to scrape the bottom of the lever when leaning your bike against a wall. Otherwise, they work better for me than any modern ergonomic bars.brentono wrote:Track Bars. Brakes?
Personally, might work for a ride down to the cafe, looks nice and would impress.
But I wouldn't want to be on a 160Km training run/or race in that position
(though i've not done it in years)
... but you would sure end up with a sore back and neck, I have no doubt.
- humanbeing
Postby humanbeing » Mon Jan 02, 2012 1:44 pm
PM'd CheersLoveMiyata wrote:Ive got a set of those I'm trying to sell at the moment. Only chasing a 10er. Only problem is they lost one of the cinelli stickers. Let me know if you are interested, I'm in Woolloomooloo
- munga
Postby munga » Mon Jan 02, 2012 2:27 pm
maybe toff does ride to the cafe, look nice and impress people.brentono wrote:If the shoe fits, wear it.toff wrote:Those bars are the "Gimondi Bend" which 3TTT used on several of their models, including their track bars, and their Competizione bars. They are essentially the same shape as the Cinelli Criterium bars, but with about a cm of extra drop. I use either Gimondi bend or Criterium bars on all my bikes. The only problem you get is that the bottom of the brake levers jut out to the side a bit, as a result of the bar's curve, so it is possible to scrape the bottom of the lever when leaning your bike against a wall. Otherwise, they work better for me than any modern ergonomic bars.brentono wrote:Track Bars. Brakes?
maybe he does 160km training rides.
really mate, just coz you were an elite cyclist 30 years ago doesn't make everyone else wrong. it just makes you a grouchy old know-it-all in my book.
- brentono
Postby brentono » Mon Jan 02, 2012 2:55 pm
I may be a Retrogrouch, but did you ever stop to think that toff seems to
have to point out stuff, for what? and he may be telling me how to suck eggs.
It states on the image details, what they are-
vintage-handlebar-3ttt-gimondi-40-track-pista-profil-260mm
(save it for the school yard, and impress the other kids)
My first post was light, about Track bars/Brakes and didn't need a lecture.
Thanks. And my informative, about long rides, about that setup, was just that.
Don't know where toff was in the seventies, but here's my criterium bike
(full campag group)
... maybe he can identify the bars on the white bike on the right?
(part of the photo is cut off, so put it on your HD)
... and Munga, "in your book"... is that the book that hadn't even started
when this photo was taken.
- HappyHumber
Postby HappyHumber » Mon Jan 02, 2012 4:40 pm
- drubie
Postby drubie » Mon Jan 02, 2012 8:02 pm
(already posted in the fixie part of the site but what the hell)
They're fine - work quite well in fact.
- brentono
Postby brentono » Tue Jan 03, 2012 11:00 am
Looks good, and we know it works... great for short runs to the shop.
(and criteriums, if that's your bag)
Please report back if you get out for a long run, and we will see how you go.
My informative, was from experience, and the pain was real (over 80km it kills)
Let us all know.
- drubie
Postby drubie » Tue Jan 03, 2012 11:28 am
- brentono
Postby brentono » Tue Jan 03, 2012 1:00 pm
Good luck commuting with that. Should be OK.drubie wrote:Brentono - the frame is a total klunker (stamped dropouts, no water bottle, weighs 2x normal bike weight) and is just for blasting to work and back - there is no way I'm riding it 80km in a single sitting
Back in the day, wouldn't even bother to throw the leg over, out on the road, under 80Km.
50 miles old money.
And a tough session, was working towards the imperial ton... no water bottle, either.
(on a bike much like you have there, except for the wheels- we had singles)
- rokwiz
Postby rokwiz » Tue Mar 06, 2012 6:13 pm
I've been reading back through some of the threads and found this interesting one.
Yeh my "Super V" has Cinelli Giro bars (44's) and Sachs Ergopower levers which I've been using since 1995 when I bought this bike new. It has done well over 65 000km now. I found the normal round bars to be the most comfortable. This bike has done many long km offroad MTB, offroad touring with a trailer, on road commuting (read carrying masons tools) and various MTB races and road Time Trials. ( I really liked the race of truth)
The only thing I didn't like was the way you normally set the ends of the brake levels end level with the ground and end tips of the bars, as usually shown in bike mech books on set up. I've noticed euro pro riders tend to have their levels set rather high on the bars as well. yeh 200km plus a day, they need to.
My bar consists of MTB tube cut into strips, then wrapped like bar tape, followed by two layers of bar tape (Cinelli at present)combined with dual suspension gives me a plush ride.
Geoff
