Thoughts on modern mass produced 650B randonneurs
- singlespeedscott
Re: Thoughts on modern mass produced 650B randonneurs
Postby singlespeedscott » Tue Jul 16, 2019 10:03 am
The build is -
1986 Raleigh Royal frame and fork built with 100% Reynolds 531 “Special Tourist”
Headset - Odessey Pro needle bearing
Stem - Nitto Pearl 90mm
Handlebar - Nitto B185 40cm
Seat post - 27.2mm Campagnolo Record
Saddle - Brooks Swift
Brakes - Dia-Compe 980 cantilevers
Brake levers - Dia-Compe DC204QC with white hoods
Cables - Campagnolo in White
Shifters - Shimano 105 7 speed running in friction mode
Rear Derailleur - Shimano XT shadow 9 speed
Front Derailleur - Campagnolo Victory
Chain - Shimano 9 speed XT
Cassette - 14-32 Hg 50 7 speed
Bottom Bracket - Campagnolo Centaur 111mm
Crankset - Campagnolo Victory with 46/35 chainrings
Mudguards - SKS
Pedals - Shimano R600
Bottle cages - King Iris
Bar tape - Shellaced white cotton
Tyres - Front - Compass Stampede Pass, Rear - Panaracer Gravel King file tread 32mm
Front rack - Nitto M12
Handlebar Bag - Gilles Berthoud
Its still a work in progress and I have plenty of changes to make -
Replace the plastic SKS mudguards with metal.
Replace the Shimano 105 7 speed shifters with Suntour Sprint retro friction.
A taller handlebar bag so I can use my Compass Decaleur (I got it new for half price ) currently it’s held in place with a couple of leather toe straps and two zip ties to stabilise it .
Swap the Brooks Swift for my B17 Narrow, I’m just breaking in the Swift for my Noosa Strade Bianche bike
A new set of wheels are to be built using some NOS Shimano DX hubs converted to 126mm and Pacenti Brevet rims or polished Sun CR18’s, I cant decide yet.
Replace the cable hangers with some Rene Herse ones
Some Nitto lamp mounts so I can move the headlight, and the other headlight I have on order, down onto the rack.
- 10speedsemiracer
Postby 10speedsemiracer » Tue Jul 16, 2019 10:09 am
- ldrcycles
Postby ldrcycles » Tue Jul 16, 2019 1:50 pm
- singlespeedscott
Postby singlespeedscott » Tue Jul 16, 2019 3:05 pm
No..well maybe, it depends if I can get my "new" Gazelle frame built up in time.ldrcycles wrote:Lovely, will that be your Strade mount this year?
- familyguy
Postby familyguy » Tue Jul 16, 2019 3:31 pm
Very nice. Very beard. Should be a ripper. I have a Clamont* built from 531ST, no real weight penalty over 'regular' 531 but touted as a loaded touring tubeset.
* may or may not be a Clamont, have not yet asked enough.
- singlespeedscott
Postby singlespeedscott » Tue Jul 16, 2019 4:03 pm
From what I understand, there are two versions of 531ST. The first version is "Special Tourist", which is used on this Raleigh.familyguy wrote:Are you only allowed to ride that wearing SPD sandals?
Essentially it is identical to regular 531c except the chain stays are and down tube have are slightly thicker butting, exactly where you want it IMO.
The other version is "Super Tourist" which uses heavier graded tubing with thicker butts all round.
- familyguy
Postby familyguy » Tue Jul 16, 2019 5:14 pm
- Thoglette
Postby Thoglette » Tue Jul 30, 2019 11:43 am
And being imported into Aus (for sub $2K see here)
- singlespeedscott
Postby singlespeedscott » Wed Jul 31, 2019 5:46 am
Looks interesting. I’m not so sure why they used the why oversized steerer if they are using a steel fork. Im not a fan fork of straight bladed forks either. Give me a nice j bend every time.Thoglette wrote:Saw a Breezer Doppler yesterday, set up with a SON dyno system. Rather neat.
Postby wqlava1 » Sun Nov 24, 2019 1:39 am
- singlespeedscott
Postby singlespeedscott » Sun Nov 24, 2019 10:28 pm
Postby wqlava1 » Mon Nov 25, 2019 12:00 am
The front hub’s bearings had problems and I sent it to Taiwan to be fixed by SP who are easy to deal with and pretty cheap. Now that I have to rebuild one wheel anyway I’m going to use the 36hole Brevets I got ages ago which has freed up the Kebas. My history has been to accumulate but these days I’m trying to pass things along so that someone else gets use/enjoyment.
- Thoglette
Postby Thoglette » Mon Nov 25, 2019 1:31 am
Agreed. Much better looking and the forks have a hope in hell of working properly
- Rob74
Postby Rob74 » Sun Aug 16, 2020 9:18 am
https://www.youtube.com/watch?v=PsuCXW2z54A
Custom Steel Bicycle All Road Bike: The Complete Build
Feb 7, 2019
Goal: Bike suited to long distance self-supported rides with clearance for large tires, but also light enough for mixed terrain races.
Outcome: 23lb = 10.43kg Total
https://www.youtube.com/watch?v=W-8guJd5qnY
Fitz Cycles Custom Bike 1 Year Review
Jan 24, 2020
Rob
- singlespeedscott
Postby singlespeedscott » Tue Aug 18, 2020 3:50 pm
https://www.instagram.com/chapmancycles/
- WyvernRH
Postby WyvernRH » Fri Apr 30, 2021 2:30 pm
So... I need to buy a pair of 36h 650B rims of 'traditional' section that can take sidewall brakes. I thought this would be easy since MTB's now use this size (erm, sorry, 27.5" ) but it is proving a lot harder than I thought as most are for disk brakes or have a deep section.
Can anyone suggest a source for a set of 650B rims that would not look amiss on a 1950's bike? I would prefer alloy but I'll consider steel.
EBay has not proven very helpful so far....
Postby wqlava1 » Fri Apr 30, 2021 2:46 pm
- Thoglette
Postby Thoglette » Fri Apr 30, 2021 4:43 pm
Pm coming..
- 10speedsemiracer
Postby 10speedsemiracer » Sat May 01, 2021 1:32 am
Maybe the Velocity Quill in 36h 650b,WyvernRH wrote: ↑Fri Apr 30, 2021 2:30 pmI've recently acquired an early 1950's MotoConfort randonneur frameset. Unsurprisingly the canti bosses are set up for 650B rims.
or the Cliffhanger in 36h 650b.
Both come in all silver with machined sidewalls. For cost-effective rims, Velocity are my go to.
I think, in silver and devoid of decals, either of these may be in keeping with the build ..
Postby LG » Sat May 01, 2021 8:16 am
I've got a single alloy araya rim from the 70s-80s, if you happen to source another individual.WyvernRH wrote: ↑Fri Apr 30, 2021 2:30 pmI've recently acquired an early 1950's MotoConfort randonneur frameset. Unsurprisingly the canti bosses are set up for 650B rims.
- baabaa
Postby baabaa » Sat May 01, 2021 1:28 pm
http://www.arayathailand.com/index.php/ ... randonneur
been looking for the same thing to do a rim swap away from 650c
https://www.somafabshop.com/shop/produc ... tegory=807
32 or 36 hole
or
https://alexscycle.com/products/araya-t ... incher-rim
ARAYA TX-310F 650B Clincher Rim
Size: 650B / 27.5"
23mm wide x 14.7 deep
Spoke Holes: 36H
Machined Braking Sidewalls
Eyeletted Spoke Holes
Pinned Joint
Weight: 475g
Postby Imwit » Sat May 01, 2021 5:42 pm
How are you going with the other bits required?
I bought a 50’s French velo de ville frame a few years ago. It hasn’t been a priority (the frame is still at my cousins in the Blue Mountains) but finding the appropriate parts locally seems rare and French postage is pretty pricey.
- WyvernRH
Postby WyvernRH » Sun May 02, 2021 3:47 pm
Thanks all for the suggestions!Imwit wrote: ↑Sat May 01, 2021 5:42 pmHow are you going with the other bits required?
Well, Thoglette has helped me out with rims and I think I've accumulated most of the other 'French' parts from wrecked Peugeots over the years except ...the chain guard... which is pretty important as the frame has three braze-ons to support one (like it has for everything else, never seen a bike from the period with so many braze-on fittings!) I think I will have to bite the bullet and get one in from Europe as it looks like it was one of the 'short' fancy alloy types - not common here in Oz. However if anybody does know of one locally I would be interested. On first twiddle the bottom bracket feels OK which is fortunate as I believe MotoConforts of this time used Swiss threading.
Also, any suggestions as to reference sources or parts much appreciated. I'm finding less about MotoConfort bicycles from this period than I expected on the Web - mostly seems to be the later 60's 70's stuff.
Here are a couple of pics of the frame as purchased. I'll do a proper thread on it when I do the resto - which might be a while yet as I have another project in hand at the moment. The paint is tatty - very much so in places - but I will be keeping it.
Postby Imwit » Sun May 02, 2021 9:20 pm
Eg. a MotoConfort 50s randonneur and some catalog scans..https://forum.tontonvelo.com/viewtopic.php?f=70&t=37669
I reckon it would be worth looking in their velo de ville section too.
- WyvernRH
Postby WyvernRH » Mon May 03, 2021 10:02 am
Many thanks - that's a great resource!Imwit wrote: ↑Sun May 02, 2021 9:20 pmTon Ton Velo forum is really good for French stuff.
I even get to practice my dodgy French....
I think the bicycle in the linked post is a little later than mine but is very complete. I love the little 'M's cut into the attachment plates each side of the rear carrier! I might have to make myself one of those....
