Duck's Tech - Compatibility Notes
- Duck!
Re: Duck's Tech - Compatibility Notes
Postby Duck! » Thu Dec 12, 2019 4:56 pm
Postby piledhigher » Thu Dec 12, 2019 8:07 pm
- MichaelB
Postby MichaelB » Tue Feb 11, 2020 8:05 am
Building up a bike and want to run a GRX600 crank or similar.
Will the Shimano cranks like CX50/70 or GRX series fit the 73mm wide shell with the outboard bearing BB ? Or do I need a MTB crank/BB386 compatible version ?
Also, what is difference between Shimano road BB and MTB BB ?
Ta
- Duck!
Postby Duck! » Tue Feb 11, 2020 11:44 am
BB386 cranks won't work, they're the same spindle length as standard road (86mm shell, same as road press-fit, and same assembled width as 68mm BSA outboard), just with a 30mm diameter spindle.
The only real difference between road & MTB bottom brackets is the extra assembled width of the MTB versions.
- MichaelB
Postby MichaelB » Tue Feb 11, 2020 11:50 am
PFBB.Duck! wrote: ↑Tue Feb 11, 2020 11:44 amMTB or road triple crank for you. GRX & CX-series cranks are basically road cranks, and the spindle length is too short for the wider BB shell. MTB cranks have a longer spindle to allow for wider frames, plus the option of BB-mounted "E-Type" front derailleurs or chainguides. Road triples are also longer & spaced out to fit the extra ring on, so will have a bit in reserve to fit the wider shell. 4703 Tiagra could be an option, then play around with chainrings to suit.
Shimano MTB Cranks seem to be 38/28 (on 96/64 PCD) combo's as biggest chainrings Some more googling to do ....
- Duck!
Postby Duck! » Tue Feb 11, 2020 11:54 am
- MichaelB
Postby MichaelB » Tue Feb 11, 2020 12:21 pm
I suppose this wouldn't work as it's 9/10sp whereas I'm wanting to run 11sp ?
It looks like I'm pointed down the direct mount route (or get creative with a file and 2.5mm from each side )
Aside from the chainring stuff, the assumption is that the FD-CX70 would still work with the much smaller chainrings ?
- Duck!
Postby Duck! » Tue Feb 11, 2020 12:59 pm
BCD will be your problem; Shimano don't use 96mm.....
- MichaelB
Postby MichaelB » Tue Feb 11, 2020 1:04 pm
Running into all sorts of problems ....
If I run a Shimano MTB cranks with 38/28, I can get roughly the same low gear with an 11-34 cassette, but lose out on the top end (by ~ 5km/hr at 90rpm.
Not huge, but not brilliant either. Googling to do ....
- Duck!
Postby Duck! » Tue Feb 11, 2020 1:08 pm
- MichaelB
Postby MichaelB » Tue Feb 11, 2020 1:17 pm
Something like this Altus Triple 44/32/22 and ditch the inner 22 ?Duck! wrote: ↑Tue Feb 11, 2020 1:08 pmThat's why I suggested something like the 4703.... Same bolt pattern as the rest of Shimano's current road/cross range, with the longer spindle to fit the wider shell. Turf the little ring (or keep it & turf the big one), there'll be options to get the rest of the combo you're after.
Looking at the Shimano Techdocs, there is the 11sp FC-M9020-3 (656g) & M8000-3 with 40/30/22 (773g) w 96/64 BCD.
There is also the Trekking option of FC-T8000 with 48/36/26 (or 44/32/24) on 104/64 PCD, but it's a heavy beast at 868g.
Affordability and availability are an issue though on the 11sp options
- Duck!
Postby Duck! » Tue Feb 11, 2020 1:27 pm
- MichaelB
Postby MichaelB » Tue Feb 11, 2020 1:35 pm
Per the Techdocs, the 4703 only shows compatibility with the 68 & 70mm shells ?Duck! wrote: ↑Tue Feb 11, 2020 1:08 pmThat's why I suggested something like the 4703.... Same bolt pattern as the rest of Shimano's current road/cross range, with the longer spindle to fit the wider shell. Turf the little ring (or keep it & turf the big one), there'll be options to get the rest of the combo you're after.
- Duck!
Postby Duck! » Tue Feb 11, 2020 1:42 pm
- MichaelB
Postby MichaelB » Tue Feb 11, 2020 1:54 pm
Ah, OK.
So grab a 4703 that comes with 50/39/30, and then get the CX sized chainrings (e.g. 46 outer & 34 middle) to fit ? Then sell off the chainrings I took off ?
Sorry for all the dumb questions, but double checking that 10sp chainrings work with 11sp chains ?
- Duck!
Postby Duck! » Tue Feb 11, 2020 2:02 pm
- MichaelB
Postby MichaelB » Tue Feb 11, 2020 2:11 pm
Solve one problem, create another
- MichaelB
Postby MichaelB » Tue Feb 11, 2020 8:38 pm
Had a second look at this one, but it's square taper BB and 180mm Q-factorMichaelB wrote: ↑Tue Feb 11, 2020 1:17 pm...
- MichaelB
Postby MichaelB » Tue Feb 11, 2020 10:41 pm
Would any of these chainrings fit on a Deore XT M8000 Crankset (normally 38/28) ? (not that they are the best option or right price, but they give me other options ...
Outer chainrings (96mm PCD)
M672 40T
M8000 40T
M7000 40 T
Metra M5000 46T
M4000 40T
As for inners, it looks like the 28T is the biggest Shimano one for 64mm PCD.
I reckon I could live with the 40/28 or 42/28 combo (yeah, not much change from the 38/28), but then might even look at the 36/26 M8000, and change it to 40/26 or 40/24, and still run the 11-36 or 11-34 cassette ....
- Duck!
Postby Duck! » Wed Feb 12, 2020 11:59 am
- MichaelB
Postby MichaelB » Fri Feb 21, 2020 1:53 pm
But the 42T that will be mounted as a single ring, what are the correct length bolts ? Just use the same ones as suitable for 1x ?
Such as these ? 6.5mm vs 8.5mm ?
Alloy Chainring Bolts
- Duck!
Postby Duck! » Mon Feb 24, 2020 11:50 am
Postby Calvin27 » Mon Feb 24, 2020 11:58 am
I have a 5701 RD 10sp which barely manages a 30t cassette. Looking at casette options now and looks liek there is an ultegra 12-30 for $80 but then the prices seem to drop a fair bit for 11-32 and 11-34. I've always wanted a wider range and now that the bike is doing off road duties the wider cassette is appealing.
So question is what derailleurs are compatible and further more where do I even buy these - no one seems to stock 10 speed anymore and the stuff that is available is goeblocked!
My options look like (appreciate compatibility notes here)
- 5701 GS which can do up to 32t. I like this option but given my current RD is rated to 30t and struggles, I'd like a bit more.
- 10 speed Tiagra SS/GS (I think these might be different pull, but the SS rated to 33t whouls do the job.
- 10 speed GRX (not sure if compatble, pretty sure it's based off the tiagra pull)
Thanks in advance.
Cushy dirt bike
Very cushy dirt bike
Bike crushed by car (RIP)
No brakes bike
Ebike
- Duck!
Postby Duck! » Mon Feb 24, 2020 1:37 pm
- 10speedsemiracer
Postby 10speedsemiracer » Mon Feb 24, 2020 9:00 pm
Calvin27 wrote: ↑Mon Feb 24, 2020 11:58 amHi @Duck!,
The other option is to look at the crankset.
Thanks in advance.
