Best option for lower gearing (Shimano road 10 speed)?
MattyK
Postby MattyK » Wed Nov 21, 2018 10:53 pm
Hi! (Quack!)
My wife is doing a ride event in Tassie next year, will be hitting quite a few hills. She's training but not a super strong rider. So some lower gears might be nice.
Bike has Ultegra 6700 with a short cage rear d, 50/34 x 12-28
Second to a cup of concrete, what's the best (read cheapest) option for getting some extra low gears? (without compromising top end)
I think 30T is as big a cassette as possible without changing anything else (new chain assumed).
Could a 32 or 34T cassette work with a hanger extension link? Or is the short cage derailleur (capacity) the limitation?
The only 10-speed medium cage derailleurs I can see still available are 105 5700. That would open up more options at the expense of the additional... expense.
Thanks! (Quack quack!)
Re: Best option for lower gearing (Shimano road 10 speed)?
Postby Duck! » Wed Nov 21, 2018 11:25 pm
Depends on the exact age of the bike. 6700 got a late-model update for 2013-model year (released mid-2012) which tweaked the derailleur geometry to fit up to 32T; the pre-update version will not happily take larger than 28 even in longer form. If it's a late version it WILL fit the 32, even in short form, but be more careful than usual to avoid the big ring/big sprocket combination; it will do it, but puts a lot of stress on the derailleur. Goat Link-type hanger extenders help with gaining sprocket clearance, but total gear range is still limited by the slack-absorbing capacity of the derailleur cage, and you won't really gain much extra overall range because of that limitation with the short cage.
The second issue of hanger extenders is that they bugger up the shifting in the smaller sprockets. The derailleur slants up/down at a certain angle through its travel to match the gradient of the cassettes it's supposed to work with. Oversized cassettes change the gradient relative to the derailleur path too much, so lowering it to clear the big sprocket means the top derailleur pulley moves further away from the sprockets as you shift to the smaller ones, so the chain tends to flex rather than shift across the gears.
The absolute best, but definitely not cheap way to gain proper low gears without losing the top end is to convert to a triple-ring crank, but that requires both derailleurs (longer rear is essential for the necessary chain length for the triple, and the front needs a deeper cage for the third ring), crank and left shifter.
MattyK
Postby MattyK » Thu Nov 22, 2018 11:26 am
Duck! wrote:the pre-update version will not happily take larger than 28 even in longer form. If it's a late version it WILL fit the 32,
Thanks for the reply.
Is there any easy way to identify the difference? Bike was bought in 2014 (Merida Scultura 905)
march83
Postby march83 » Thu Nov 22, 2018 11:49 am
Not sure on pricing, but a tanpan from wolftooth, a cheap Shimano MTB rear derr (SLX?), a MTB cassette like a Shimano 11-36 or sunrace 11-42 or 11-46 and a new chain would provide a massive range.
I ride something similar on my daily commuter. It's 1x with an 11-42 rear. In your case 11-36 would probably be the option to keep total chain length sensible. Wolftooth has some decent articles on their website about 2x combinations that work with their tanpans and you definitely want to go through them to pick a combo that actually works.
redsonic
Postby redsonic » Thu Nov 22, 2018 1:05 pm
I think the model number on the back will be RD6700 A. The older type didn't have the A on it.
Ivanerrol
Postby Ivanerrol » Thu Nov 22, 2018 10:30 pm
I have a rear wheel with an 11 - 32 Cassette (The cassette alone weighs 500 grams).
On one bike I'm running a 50/34 with 4700 mid cage with no issues with the 11 - 32 installed - except using 34/32 is very slow.
4700 wont work with 6700 shifters.
Another bike I use the same wheel and rear cassette. Runs 52/39 front with 5700 mid cage.
Needed to lengthen the chain by 2 links to run this combo.
Big jump between gears though.
Postby Duck! » Thu Nov 22, 2018 11:15 pm
Although known as both 6700A and 6701, I don't think the ID stamping was changed to suit, just to be difficult. Some examples had 30T stamped on the top of the outer cage plate, but that doesn't appear to have been consistent, so its absence isn't necessarily a positive indicator of an early model. If the bike was purchased new it will be the later model; given the change was made mid-2012 for MY13, anything built after then will have the updated version.
Postby Duck! » Thu Nov 22, 2018 11:22 pm
Ivanerrol wrote:I have a rear wheel with an 11 - 32 Cassette (The cassette alone weighs 500 grams).
4700 is designed to take a 34T sprocket. Even the shortie will do it. The longer option is beacuse the Tiagra series still includes a triple-ring option. But as you correctly say, it won't work with other 10-sp. shifters.
march83 wrote:Not sure on pricing, but a tanpan from wolftooth, a cheap Shimano MTB rear derr (SLX?), a MTB cassette like a Shimano 11-36 or sunrace 11-42 or 11-46 and a new chain would provide a massive range.
Or use a "9-sp." Shadow-type MTB derailleur which works on the same cable pull ratio as road 10-sp, so no mucking around with ratio converters, and they'll play with up to 40T sprockets (although officially only 36T).
caneye
Postby caneye » Mon Nov 26, 2018 1:25 pm
I had a 6700 short derailleur. not sure if it's the revised "A" one, but it was short. Ran it with 50/34 and 12-27 cassette.
I then added a wolf tooth roadlink and used it with a 32T cassette with no dramas at all.
Bentnose
Postby Bentnose » Tue Nov 27, 2018 9:20 am
I had a 9 speed xt with 11-36 10 speed slx cassette coupled with 5700 brothers, all worked fine. I've since gone to a triple on the front 26-36-48, still the same on the rear, all works though that front crank and rings seems to be a bit harder to get these days
No signature
MattyK
Postby MattyK » Sat Dec 08, 2018 3:55 pm
Duck! wrote:Although known as both 6700A and 6701, I don't think the ID stamping was changed to suit, just to be difficult. Some examples had 30T stamped on the top of the outer cage plate, but that doesn't appear to have been consistent, so its absence isn't necessarily a positive indicator of an early model. If the bike was purchased new it will be the later model; given the change was made mid-2012 for MY13, anything built after then will have the updated version.
Good news, 30T identified :)
For those who want to know what to look for:
antigee
Location: just off the Yarra Trail but not lurking in the bushes
Postby antigee » Mon Dec 10, 2018 9:16 pm
Bentnose wrote:I had a 9 speed xt with 11-36 10 speed slx cassette coupled with 5700 brothers, all worked fine. I've since gone to a triple on the front 26-36-48, still the same on the rear, all works though that front crank and rings seems to be a bit harder to get these days
same on my most often ridden 10speed 105 STI's triple mtb touring 26-36-48 with a 36 outback and a 9speed XT rear mech
agree had to scrape around to find triple STI's and the triple groupset after pilot error bent a crank and took out an STI :(
to sort of future proof have newer bike use for gravel touring and that has 10speed 105 STI's with an XT double chainset 40/24 and 36 outback with a 9speed mtb mech and shifts very cleanly
so to answer OP reckon good way of getting what want would be a 9speed MTB mech with an 11-36 cassette and the rest as is and no link adaptor - google tells me Deore available $65-$85 I'd avoid rapid rise / top normal versions - not sure how work with STI's and would prob' feel a bit odd - don't forget not stuck on shimano road cassettes - reckon I usually end up buying SRAM MTB cassettes based on combo of weight and price 34-36 versus 34-28 is a big difference if not enough then consider a 40t or 42 out back with adaptor
MattyK
Postby MattyK » Mon Dec 10, 2018 10:12 pm
Thanks. I'm going to stick to a Sunrace 11-32, should be sufficient.
If I ever decide to convert my bike to 1x10 I'll remember the above tips.
Postby Duck! » Mon Dec 10, 2018 10:14 pm
antigee wrote: (snip... 9-sp. compatibility stuff....) I'd avoid rapid rise / top normal versions - not sure how work with STI's and would prob' feel a bit odd ...
Rapid Rise is/was Low Normal, not Top/High Normal; conventional and Shadow derailleurs are High Normal - "Normal" in Shimano parlance refers to the resting position of the derailleur when there is no cable tension. The vast majority of rear derailleurs spring to the outboard/high gear/small sprocket position when released from cable tension, so are "high normal". Rapid Rise, which is a bit of a thing Shimano had for a couple of generations of MTB derailleurs are reverse-sprung so when freed of cable tension default to the inboard/big sprocket/low gear position, hence they are described as "low normal". Rapid Rise with STI shifters won't feel any more odd than with MTB/flat bar shifters; in both cases the lever functions for up or downshift are swapped, so you just have to remember that when you're riding with it. Aside from that, the actuation ratio is the same, so it'd still work just as well, just arse-about.
Rapid Rise (Low Normal) and conventional High Normal derailleurs will not happily support greater than a 34T rear sprocket; the upper body geometry plus the sprung/unstopped main pivot/mount simply don't let the derailleur stay low enough. To fit 36T or bigger you need a Shadow (which without exception are regular High Normal format) derailleur. Shadow's original marketing point was that it's a considerably lower lateral profile than a traditional derailleur design, tucked in tighter under the frame & cassette, so less exposed to damage, but it's big advantage - especially in the context of the current scenario - is that the upper pivot is unsprung (except for some newer, lower-spec models {where the spring is entirely unnecessary anyway!]), therefore the b-tension screw, used to adjust vertical clearance, is a positive stopper against forward movement of the derailleur body, therefore ensuring consistent clearance under the big sprocket - within geometric limitations. 9-sp. Shadow models will happily fit up to a 40T sprocket, despite the official specs saying a 36T max....
stevenaaus
Postby stevenaaus » Sun Jul 17, 2022 9:46 pm
Duck! wrote: Or use a "9-sp." Shadow-type MTB derailleur which works on the same cable pull ratio as road 10-sp, so no mucking around with ratio converters, and they'll play with up to 40T sprockets (although officially only 36T).
I bought some mtb parts tonight for my 10 roadie. A (tiagra) 10x 11-34 cassette, and an alivio shadow RD-M3100. Almost went for a bargain $26 Altus rear mech - I've always found Altus decent - but thought I'd do it proper.
'Bout $60 each. Just messing around, I've got a few 10-ers. Maybe I'll match it with a 52/36?
Thoglette
Postby Thoglette » Sun Jul 17, 2022 10:35 pm
Grant Petersen (of Rivendell bicycles) considers the Altus "The best-designed cheap rear derailer in existence"
Oh, where did you see it for $26? I need to rebuild the commuter in another few thou' km
Thoglette
Postby Thoglette » Mon Jul 18, 2022 8:58 am
Ta!
stevenaaus
Postby stevenaaus » Wed Jul 27, 2022 7:54 pm
So , the kit has arrived. After much deliberating, i'm thinking of putting it on my 2016 Defy Ad with 32mm tyres which is my only Gravel sort of bike. It currently has a compact + 11-32t on it, but i *do* run out of gears on it when going up dirt, so 34t will be a slight improv.
Net gains - i get a spare 11 speed groupo for a new road build, see if my cheap 5600 shifters work, i go from 32t to 34t, and have a bit of fun :)
Duck! Will it work ? I've seen some conflicting reports say the shadow rear mechs (Mine is a rd-m3100-sgs ) won't work with 10 speed shifters. It'll be a bit of an effort, new shifters, chain (length), mechs and cassette. I'm hoping the 10 speed shifters will pull the TRP Spyre cable disc brakes ok.
2wheels_mond
Postby 2wheels_mond » Wed Jul 27, 2022 8:58 pm
The M3100 rear derailleur will work with the (non-Tiagra 4700) 10 speed road shifters. Shadow is not the issue, it's the items labelled 'Dyna-Sys' (found on 10 speed and up) that are incompatible with road parts.
The other giveaway is the barrel adjuster - any (current) Shimano MTB rear derailleur with a barrel adjuster works with road shifters. The higher end parts don't need barrel adjusters (since on MTBs they're at the lever).
Postby Duck! » Wed Jul 27, 2022 9:41 pm
9/10- sp. shifter/derailleur incompatibility is specifically within the MTB family; Shimano changed the actuation ratio (cable pull for derailleur movement) for MTB 10-sp, however road 10-sp. (except 4700 Tiagra, that's another chapter) and all 9-sp. & below use a common actuation ratio. Your proposed setup of 5600 shifters and M3100 derailleur will be fine.
On the braking side, again should be pretty OK, but depends a bit on caliper leverage.... From about 2009 onward (7900 Dura-Ace & derivatives), Shimano brakes worked on a longer cable pull. Paired with older-spec calipers, this can make the brakes aggressively grabby. Going the other way, newer-leverage calipers with older levers can use a lot of the lever stroke for not a lot of effect.
Postby Duck! » Wed Jul 27, 2022 9:49 pm
Not necessarily true, numerous MTB derailleurs that are compatible with road shifters do not have an inbuilt barrel adjuster. However there are various "in-line" adjusters that can be fitted to the shift cable outer casing to enable tuning.
2wheels_mond
Postby 2wheels_mond » Wed Jul 27, 2022 9:57 pm
That's why I specified current. Of the current MTB series, Alivio M4000 and below RDs are compatible with road. They all have barrel adjusters at the RD.
stevenaaus
Postby stevenaaus » Wed Jul 27, 2022 9:57 pm
Great. I'll find some time and swap out my 11 speeds for the alivio mech, bigger cassette and 10 speed shifters. The derailleur looks swish alright.
Postby Duck! » Wed Jul 27, 2022 10:25 pm
"Older" models such as M590-series Deore and M770-series XT have remained in production well after their replacement as "current" models. Some of the 590 variants have barrel adjusters, none of the 770s do, yet are compatible with road shifters. Presence of a barrel aduster is not an indication of compatibility. Aside from 7400 Dura-Ace and 4700 Tiagra (the latter including non-series RS405 hydro brifters) all Shimano 5-9-sp. + Road 10-sp. shifters & derailleurs are compatible.
